HP EliteDisplay E272q LED Monitor 27" 2650x1440 QHD IPS
Key features
  • Create a comfortable work environment with adjustable tilt, height, swivel, and pivot settings.
  • Enjoy easy connectivity to your PC platform and everyday devices with HDMI, DisplayPort, VGA, and USB ports.
  • Put all your work onscreen on the 68,6 cm (27”) diagonal screen, and get fantastic color and views from quad HD resolution, 3.6 MP, and 178-degree viewing angle IPS.
Product codes
Multi-task to your heart's desire in Quad HD on the HP E272q 68,6 cm (27") QHD Monitor, which also has adjustable comfort features to help you power through your day.
Product Description HP EliteDisplay E272q - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 55 kWh
Power Consumption (On mode) 38 W
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 7 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black, silver
Dimensions (WxDxH) - with stand 64.32 cm x 19.7 cm x 40.94 cm
Weight 6 kg
Localisation English / United Kingdom
Pricing Type Promo
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified
Compliant Standards CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, TCO Certified Edge, KC, CECP, EAC, CEL Grade 1, ISC, SEPA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E272q...
