HP EliteDisplay E273 27" 1920x1080 5ms VGA HDMI LED Monitor
£204.00
1 due in 3-4 days
Delivery:
Key features
  • Connect to your most frequently-used displays and devices with a range of integrated ports right at the display.
  • Expand your productivity with uninterrupted views on a high resolution, 3-sided micro-edge bezel IPS screen that supports virtually seamless multi-display arrays.
  • Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings.
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E273 68.58 cm (27") Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through your day.
Product Description HP EliteDisplay E273 - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A+
Energy Consumption per Year 24 kWh
Power Consumption (On mode) 16 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.311 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (On/Off)
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, anti-static
Dimensions (WxDxH) - with stand 61.09 cm x 21.39 cm x 52.26 cm
Weight 7.02 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, TCO Certified Edge, KC, CECP, CEL, EAC, ISC, low halogen, ICE, SmartWay
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E273 2...
£204.00
