HP EliteDisplay E273q 27" 2560x1440 5ms VGA DVI DisplayP...
HP EliteDisplay E273q 27" 2560x1440 5ms VGA DVI DisplayPort IPS LED Monitor
£422.79
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Bring more of your data to the screen at the same time and get efficient column and row management and smoother image curves on a massive 68.58 cm (27") diagonal screen with Quad HD 2560 x 1440 resolution.
  • Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings.
  • Keep your workspace clean with single-cable video and data over USB-C™; be ready for multi-generation products with DisplayPort™, HDMI, VGA, and a 2-port USB hub.
  • Take visual disruptions out of the picture with the display’s 3-sided micro-edge bezel, which essentially removes them from your line of sight for virtually seamless multi-display arrays.
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £426.28
Save £1.50
Style meets substance in the strikingly modern HP EliteDisplay E273q 68.58 cm (27") QHD Monitor, a Quad HD display crafted for optimal viewing, productivity, and ergonomics with a 3-sided micro-edge bezel for seamless multi-display tiling, flexible USB-C connectivity, and 4-way adjustable comfort.
Product Description HP EliteDisplay E273q - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.2331 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black (rear cover), silver (front bezel, frame and stand)
Dimensions (WxDxH) - with stand 61.26 cm x 21.4 cm x 52.29 cm
Weight 7.4 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, PSE Mark, cTUVus, MEPS, CECP, CEL, EAC, ISC, RCM, MSIP, CoC, low halogen, ICE, SmartWay
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E273q...
£422.79
