HP EliteDisplay E273q 27" 2560x1440 5ms VGA DVI DisplayP...
HP EliteDisplay E273q 27" 2560x1440 5ms VGA DVI DisplayPort IPS LED Monitor
£422.79
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Bring more of your data to the screen at the same time and get efficient column and row management and smoother image curves on a massive 68.58 cm (27") diagonal screen with Quad HD 2560 x 1440 resolution.
  • Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings.
  • Keep your workspace clean with single-cable video and data over USB-C™; be ready for multi-generation products with DisplayPort™, HDMI, VGA, and a 2-port USB hub.
  • Take visual disruptions out of the picture with the display’s 3-sided micro-edge bezel, which essentially removes them from your line of sight for virtually seamless multi-display arrays.
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £426.28
Save £1.50
Style meets substance in the strikingly modern HP EliteDisplay E273q 68.58 cm (27") QHD Monitor, a Quad HD display crafted for optimal viewing, productivity, and ergonomics with a 3-sided micro-edge bezel for seamless multi-display tiling, flexible USB-C connectivity, and 4-way adjustable comfort.
Product Description HP EliteDisplay E273q - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.2331 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black (rear cover), silver (front bezel, frame and stand)
Dimensions (WxDxH) - with stand 61.26 cm x 21.4 cm x 52.29 cm
Weight 7.4 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, PSE Mark, cTUVus, MEPS, CECP, CEL, EAC, ISC, RCM, MSIP, CoC, low halogen, ICE, SmartWay
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E273q...
£422.79
