HP EliteDisplay E324q 32" 2560x1440 7ms HDMI DisplayPort...
HP EliteDisplay E324q 32" 2560x1440 7ms HDMI DisplayPort LED Monitor
£451.53
Delivery:
Key features
  • Display more of your data on the screen at the same time on a massive 31.5” diagonal screen with Quad HD 2560 x 1440 resolution. No more toggling between open windows or paging up and down.
  • Minimize your line-of-sight disruptions and see more of your screen with the 3-sided micro-edge bezel. Find your sweet spot with adjustable tilt, height, swivel, and pivot settings.
  • Streamline your desk by installing your HP Desktop Mini, HP Chromebox or select HP Thin Client behind the screen, directly on the column stand.
Product codes
Astound your open office with the mammoth HP EliteDisplay E324q 31.5-inch QHD Monitor that has plenty of screen space without overwhelming your desk. Get broad device compatibility with ports that include USB-C for easy pairing with a range of HP PCs.
Product Description HP EliteDisplay E324q - LED monitor - 31.5"
Device Type LED-backlit LCD monitor - 31.5"
Features USB 3.1 hub
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.272 mm
Brightness 350 cd/m²
Contrast Ratio 3000:1 / 10000000:1 (dynamic)
Response Time 7 ms (grey-to-grey)
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Tilt
Screen Coating Anti-glare
Dimensions (WxDxH) - with stand 71.4 cm x 24.04 cm x 43.94 cm
Weight 10.3 kg
Localisation English / United Kingdom
Compliant Standards Plug and Play, TUV GS, VCCI, BSMI, CB, CCC, FCC, KCC, ICES, S Mark, cTUVus, MEPS, E-Standby, CEC, KC, CECP, CEL, ISC, RCM, SEPA, BIS, low halogen, CE/EMC, TUV LBL, IEC 62368
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E324q...
£451.53
