HP EliteDisplay S14 14" 1920x1080 5ms LED Portable Monitor
£223.10
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Control brightness, contrast, and response time, and activate HP Low Blue Light mode, all from the intuitive OSD.
  • Maximize your productivity and lighten your load with a Full HD display that weighs 1 kg and is less than 9 mm thick, so it won’t weigh you down.
  • Set up quickly with just one USB-C™ cable that transfers video and pulls power from your notebook or tablet - no power cable required.
  • Diagonal Size: 14in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Interfaces: USB-C
  • Stock Status: In Stock
Product codes
Unfold dual-display productivity anywhere you work-on your own, in groups or at client sites-with the HP EliteDisplay S14 USB Portable Monitor, HP's first portable 35.56 cm (14") USB-C display. Fold back the wraparound easel cover, stand up, and connect to your device with just one USB-C cable.
Product Description HP EliteDisplay S14 - LED monitor - Full HD (1080p) - 14"
Device Type LED-backlit LCD monitor - 14"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.1611 mm
Brightness 200 cd/m²
Contrast Ratio 700:1 / 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 262,144 colours
Input Connectors USB-C
Screen Coating Anti-glare
Colour Ebony black
Dimensions (WxDxH) - without stand 32.78 cm x 0.86 cm x 20.95 cm
Weight 1 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CECP, CEL, EAC, ISC, low halogen
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay S14 14...
£223.10
