HP EliteDisplay S140u LED Monitor 14" 1600 x 900
Key features
  • Get ready in a snap with the single USB cable that also acts as a power source. Fold back the cover and connect to any USB port on your notebook or tablet and you’re ready to work.
  • Pair the 1600 x 900 high-resolution display with a notebook or tablet to extend to a dual-display setup wherever you work, or make a big impression with mirror mode.
  • The super-compact, ultra-thin design weighs 1.44 Kilograms, and is just 1.27 centimeters thick. The cover doubles as an adjustable stand and helps protect the display so you can slide it into your carrying case with your tablet or notebook.
Product codes
Create a dual-display mobile workspace almost anywhere with the HP EliteDisplay S140u 35.56 cm (14") USB Portable Monitor, an ultra-compact, strikingly thin, high-resolution display in a wraparound cover. Fold it back to add a second screen for your Windows tablet or notebook and connect with one USB cable.
Sleek, stylish, and ultra-portable.
Double your visual workspace.
Super simple set-up.
HP EliteDisplay S140u - LED monitor - 14"
LED-backlit LCD monitor - 14"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.1935 mm
Brightness
200 cd/m²
Contrast Ratio
400:1
Response Time
8 ms (grey-to-grey)
Colour Support
262,144 colours
Input Connectors
USB
Screen Coating
Anti-glare
34.58 cm x 1.35 cm x 21.71 cm
1.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, cUL, VESA EDID, CB, CCC, FCC, C-ETL, RoHS, IEC 60950-1, KCC, ICES, S Mark, TUV Bauart, GOST-R 50377-1992, GOST 25861-83, NOM-019-SCFI-1998, ISC, RCM, ISO9241-307
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay S140u...
