HP EliteDisplay S231d 23" 1920x1080 7ms VGA DisplayPort...
HP EliteDisplay S231d 23" 1920x1080 7ms VGA DisplayPort IPS LED Monitor
£332.00
Delivery:
Key features
  • Boost productivity and lower costs with a display that does double duty as a large format monitor and port replicator that delivers network connectivity, port expansion, and HP Notebook charging—all in one device.
  • Eliminate the time and expense of travel and keep the lines of communication open with an integrated 720p HD webcam and dual microphone plus virtual conferencing software so you can meet anywhere, anytime from the comfort of your desk.
  • Get a large-screen 58,4 cm (23'') diagonal Full HD IPS panel display that’s so much more—it’s your gateway to a streamlined, personalized workspace of your pre-selected, pre-arranged, and pre-connected peripherals.
  • Diagonal Size: 23in
  • Max Resolution: 1920 x 1080
  • Response Time: 7ms
  • Speakers: None
  • Interfaces: DisplayPort, VGA (HD-15)
Product codes
Create an instant workspace with this 58,4 cm (23') IPS LED Backlit Notebook Docking Monitor. With one USB cable connection from your notebook to display, you can access everything you need and get to work. Charge your HP Notebook battery and power your HP Notebook through the display's DC power cable.
Product Description HP EliteDisplay S231d - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23"
Features USB 3.0 hub, 720p webcam
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.265 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 7 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 54.4 cm x 24.24 cm x 46.99 cm
Weight 6.12 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified EPEAT Gold
Compliant Standards Plug and Play, CSA, VCCI, C-Tick, BSMI, cUL, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, S Mark, TCO Certified Edge, E-Standby, KC, CECP, EAC, CEL Grade 1, ISC
Manufacturer Warranty 5 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay S231d...
£332.00
