HP EliteDisplay S240uj 2560 x 1440 23.8" 5ms HDMI DP USB...
HP EliteDisplay S240uj 2560 x 1440 23.8" 5ms HDMI DP USB IPS Monitor
£462.03
Delivery:
Key features
  • Break the sound barrier with integrated premium Audio by Bang and Olufsen that makes your calls and videos pop, and grab attention on all sides with a beautiful micro-edge design.
  • Redefine your “clean desk policy” when you connect a PC, notebook, tablet or phone to the high resolution 60.45 cm (23.8-inch) diagonal display with just a single USB-C™ connection.
  • See up to 77% more, expand your view, open more windows, and show content from multiple devices with Quad HD, PiP, and PbP.
  • Set your phone or tablet on the base of HP’s first fully integrated wireless charging display while you work, so it’s ready to go when you are.
Product codes
Move into the workspace of the future with the HP EliteDisplay S240uj monitor, display with fully integrated wireless charging, and USB-C. It has premium Audio by Bang & Olufsen and QHD and looks cool from every angle with just two cables on the desk.
HP EliteDisplay S240uj Wireless Charging Monitor - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
42 W
Wireless charger, USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.20535 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, HDMI (MHL), DisplayPort, USB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, anti-static
Silver
54.06 cm x 21.34 cm x 42.9 cm
5.5 kg
English / United Kingdom
Plug and Play, CSA, VCCI, BSMI, TUV S, WHQL, CB, CCC, FCC, ISO 9241-307, WEEE, ICES, MEPS, TUV Bauart, China Energy Label Level 1, CECP, CEL, EAC, ISC, RCM, MSIP, SEPA, CoC, low halogen
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay S240uj...
£462.03
