General |
Type |
Personal computer |
Product Form Factor |
All-in-one |
Built-in Devices |
Fingerprint reader |
Embedded Security |
Trusted Platform Module (TPM 2.0) Security Chip |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
Intel Core i7 (7th Gen) 7700 / 3.6 GHz |
Max Turbo Speed |
4.2 GHz |
Number of Cores |
Quad-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
CPU Upgradability |
Upgradable |
Processor Main Features |
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache |
Chipset Type |
Intel Q270 |
Cache Memory |
Installed Size |
8 MB |
Cache Per Processor |
8 MB |
RAM |
Installed Size |
8 GB / 32 GB (max) |
Technology |
DDR4 SDRAM |
Effective Memory Speed |
2400 MHz |
Rated Memory Speed |
2400 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots |
2 (Total) / 1 (empty) |
Features |
Dual channel memory architecture |
Configuration Features |
1 x 8 GB |
Hard Drive |
Type |
SSD - M.2 2280 |
Capacity |
1 x 256 GB |
Interface Type |
PCI Express |
Features |
NVM Express (NVMe) |
Storage Controller |
Type |
1 x SATA |
Optical Storage |
Type |
No optical drive |
Monitor |
Monitor Type |
LED - IPS |
Diagonal Size |
27" |
Native Resolution |
3840 x 2160 (Ultra HD 4K) |
Widescreen Display |
Yes |
Image Aspect Ratio |
16:9 |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Pixel Pitch |
0.1554 mm |
Image Brightness |
350 cd/m² |
Image Contrast Ratio |
1000:1 |
Monitor Features |
99% sRGB colour gamut, Ultra HD 4K anti-glare |
Graphics Controller |
Graphics Processor |
Intel HD Graphics 630 |
Video Interfaces |
HDMI, DisplayPort |
Audio Output |
Sound Output Mode |
Stereo |
Max Sampling Rate |
192 kHz |
Compliant Standards |
High Definition Audio |
Speakers Included |
2 x right / left channel |
Camera |
Camera |
Yes |
Resolution (MP) |
2 Megapixel (rear), 2 Megapixel (front) |
Resolution |
Full HD |
Features |
IR camera, Windows Hello |
Audio Input |
Type |
Dual array microphone |
Networking |
Ethernet Controller |
Intel I219-LM |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity |
Bays |
1 (total) / 1 (free) x internal 2.5" |
Slots |
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280 |
Interfaces |
5 x USB 3.1 Gen 1 (two of them with wake functionality, one of them is charging) , 1 x DisplayPort input , 1 x DisplayPort output , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x USB 3.1 - Type C |
Miscellaneous |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Power |
Device Type |
Power adapter |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Provided |
180 Watt |
Efficiency |
87% |
Power Factor Correction |
Yes (active) |
Operating System / Software |
OS Provided |
Windows 10 Pro 64-bit Edition English |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Dimensions & Weight |
Width |
61.33 cm |
Depth |
19 cm |
Height |
45.73 cm |
Weight |
10.2 kg |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
50 °C |
Humidity Range Operating |
10 - 95% (non-condensing) |
