General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class C |
Energy Consumption per Year |
91 kWh |
Power Consumption (On mode) |
62 W |
Diagonal Size |
34" |
Viewable Size |
34" |
Curved Screen |
Yes |
Built-in Devices |
USB 3.0 hub |
Panel Type |
VA |
Aspect Ratio |
21:9 |
Native Resolution |
3440 x 1440 at 60 Hz |
Pixel Pitch |
0.232 mm |
Brightness |
350 cd/m² |
Contrast Ratio |
3000:1 / 5000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
6 ms (grey-to-grey) |
Vertical Refresh Rate |
100 Hz |
Horizontal Refresh Rate |
145 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Backlight Technology |
LED backlight |
Features |
HDCP, anti-glare, Frame Rate Control (FRC), On-screen Digital Controls, Mercury free, arsenic-free glass, Bang & Olufsen audio |
Colour |
Black, silver |
Dimensions (WxDxH) |
80.98 cm x 19.82 cm x 47.65 cm - with stand |
Weight |
11.14 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
7 Watt |
Connectivity |
Interfaces |
2 x HDMI (HDCP) , DisplayPort (HDCP) , USB-C , 3 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in/out |
Mechanical |
Display Position Adjustments |
Tilt |
Tilt Angle |
-5/+20 |
Miscellaneous |
Included Accessories |
Wall mount, L type screw driver |
Cables Included |
1 x power cable , 1 x USB cable , 1 x USB-C cable , 1 x HDMI cable , 1 x DisplayPort cable |
Compliant Standards |
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, CE/EMC, ICE |
Localisation |
English / United Kingdom |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
70 Watt |
Power Consumption Stand by |
0.5 Watt |
Power Consumption (Off Mode) |
0.43 Watt |
Software / System Requirements |
Included Software |
HP Display Assistant |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 80.98 cm - depth: 19.82 cm - height: 47.65 cm - weight: 11.14 kg , Without stand - width: 80.98 cm - depth: 10.24 cm - height: 39.53 cm - weight: 7.66 kg |
Manufacturer Warranty |
Service & Support |
Limited warranty - 1 year |
Environmental Parameters |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
20 - 80% (non-condensing) |
