General |
Device Type |
Multifunction printer |
Printing Technology |
Ink-jet - colour |
Monthly Duty Cycle (max) |
1000 pages |
Recommended Monthly Volume |
100 - 400 pages |
Display Diagonal Size |
2.2" |
Display Features |
Touch screen |
Connection Availability |
Yes |
Interface |
USB 2.0, Wi-Fi(n) |
AirPrint Enabled |
Yes |
Office Machine Features |
HP Auto Wireless Connect, HP Instant Ink |
Localisation |
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region |
Memory |
Standard Memory |
256 MB |
Max Supported Memory |
256 MB |
Copying |
Max Copying Speed |
Up to 8 ppm (mono) / up to 4 ppm (colour) |
Max Copying Resolution |
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour) |
Copying Features |
ID Card Copy |
Printing |
Nozzle Configuration |
328 nozzles (black), 588 nozzles (colour) |
Max Printing Resolution |
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) |
Max Printing Speed |
Up to 20 ppm (mono) / up to 17 ppm (colour) |
Ink Cartridge Configuration |
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow) |
Ink Palette Supported (Colours) |
Cyan, magenta, yellow, pigment black |
Colour |
4-ink |
Printer Drivers / Emulations |
PCL 3 GUI |
Automatic Duplexing |
Yes |
First Print Out Time B/W |
16 sec |
First Print Out Time Colour |
19 sec |
Scanning |
Scan Element |
CIS |
Optical Resolution |
1200 x 1200 dpi |
Grayscale Depth |
8-bit |
Document & Media Handling |
Max Original Size |
Letter A (216 x 279 mm)/A4 (210 x 297 mm) |
Min Media Size |
76.2 x 127 mm |
Max Media Size |
A4/Legal |
Min Media Weight |
64 g/m² |
Max Media Weight |
250 g/m² |
Supported Media Type |
Plain paper, recycled paper, photo paper, light-weight paper, glossy paper, matte paper |
Supported Media Sizes |
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C6 (114 x 162 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, DL (210 x 99 mm) |
Supported Envelope Sizes |
US No 10 (104.7 x 241.3 mm) |
Borderless Photo Sizes |
ANSI A (Letter) (216 x 279 mm), 216 x 297 mm |
Standard Media Capacity |
100 sheets |
Output Trays Capacity |
25 sheets |
Document & Media Handling Details |
Input tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 250 g/m² , Output tray - 25 sheets |
Speed Details |
Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft , Printing: up to 10 ppm - B/W (ISO) , Printing: up to 7 ppm - colour (ISO) , Printing: up to 10 ppm (A4) - B/W normal , Printing: up to 7 ppm (A4) - colour normal , Printing: 52 sec (10 x 15 cm (4"x6")) - colour normal , Copying: up to 8 ppm - B/W (ISO) , Copying: up to 4 ppm - colour (ISO) , Scanning: up to 7 ppm - B/W normal , Scanning: up to 3 ppm - colour normal |
Connections |
Interfaces |
1 x USB 2.0 - 4 pin USB Type B |
Operating System Support |
MS Windows 7, MS Windows XP SP2, MS Windows Server 2008 R2 x64 Edition, Windows 8, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, Windows 8.1, MS Windows Server 2008 SP1 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), Apple Mac OS X 10.10, Windows 10, Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016 |
Software Included |
Drivers & Utilities, HP Photo Creations |
Power |
Voltage Required |
AC 120/230 V (50/60Hz) |
Power Consumption Operational |
14 Watt |
Power Consumption Standby |
3.75 Watt |
Power Consumption Sleep |
0.89 Watt |
Miscellaneous |
Included Accessories |
USB cable |
Consumables Included |
1 x Cartridge (black) - up to 120 pages - HP 304 , 1 x Cartridge (tricolour) - up to 100 pages - HP 304 |
Compliant Standards |
BSMI, PSB, KCC, CAN/CSA C22.2 No. 60950-1-07, EN 62479:2010, CNS13438:2006, EN 61000-3-3:2013, EN 301 489-17 V2.1.1, CISPR 24:2010, EN 55024:2010, EN 55022:2010, EN 62311:2008, FCC Part 15 Class B, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, VCCI V-3/2013.04, KKC certified, IEC 62311:2007, ANSI/UL 60950-1 Second Edition, EN 55032 Class B, CISPR 32 Class B, ICES-003 issue 6, AS/NZS 60950-1:2015, Directive 2014/53/EU, EN 301 489-17, EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013 |
Manufacturer Warranty |
Service & Support |
Limited warranty - 1 year |
Dimensions & Weight |
Width |
44.5 cm |
Depth |
36.7 cm |
Height |
12.8 cm |
Weight |
5.41 kg |
Dimensions & Weight (Shipping) |
Shipping Width |
48.7 cm |
Shipping Depth |
16.1 cm |
Shipping Height |
44.7 cm |
Shipping Weight |
6.45 kg |
Environmental Parameters |
Sound Emission |
51 dBA (operating) |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
20 - 80% (non-condensing) |
