Handle it all from home. Print, scan, and copy everyday documents and more, and get a 35-page auto document feeder. Set up and connect on any device, and get self-healing Wi-Fi™.
Loaded with everything. Except complications.
Work fast and hands-free – the 35-page auto-feeder helps you complete scan and copy jobs quickly.
Easily print, scan, and copy everyday documents from your smartphone, using HP Smart app.
Save time by sending a mobile fax from your smartphone, tablet, or PC for 24 months, with HP Smart app.
Easily handle tasks and get a lot from one device – print, scan, and copy.
Print then and there. From anywhere.
Get started fast with simple setup that guides you through each step, using HP Smart app.
Self-healing Wi-Fi™ automatically detects and resolves connectivity issues to help reduce interruptions.
Tap the Smart Tasks shortcut in HP Smart app for a shortcut on your phone. Scan to cloud, email, and more.
Get connected with Bluetooth® and start printing fast from your smartphone or tablet – easy setup.
*Choose to activate HP+ at printer set up. Requires ongoing internet connection, set up of an HP account and use of only Original HP Ink or Toner for the life of the printer.
Learn more: hp.com
Product Description | HP ENVY Pro 6430e All-in-One - multifunction printer - colour - HP Instant Ink eligible | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | United Kingdom, Ireland | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 1000 pages | Recommended Monthly Volume | 50 - 100 pages | Max Copying Speed | Up to 8 ppm (mono) / up to 4 ppm (colour) | Max Copying Resolution | Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour) | Max Printing Speed | Up to 10 ppm (mono) / up to 7 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 14.4 Kbps | Fax Resolutions | 150 x 150 dpi | Scanning | 1200 x 1200 dpi | Original Size | 216 x 297 mm (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | 76.2 x 127 mm (min) - ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, cards, recycled paper, photo paper, light-weight paper, glossy paper, matte paper | Standard Media Capacity | 100 sheets | Output Trays Capacity | 25 sheets | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | Interface | USB 2.0, Wi-Fi(ac) | AirPrint Enabled | Yes | Office Machine Features | Scan to e-mail, automatic paper sensor, print from mobile devices, scan to PDF | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 43.25 cm x 36.11 cm x 13.21 cm | Weight | 6.16 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Printing Technology | Ink-jet - colour |
Memory | |
Standard Memory | 256 MB |
Max Supported Memory | 256 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 9 |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Nozzle Configuration | 328 nozzles (black), 588 nozzles (colour) |
Ink Cartridge Configuration | 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, pigment black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3 GUI |
Automatic Duplexing | Yes |
First Print Out Time B/W | 21 sec |
First Print Out Time Colour | 18 sec |
Colour Management Features | ColorLok Technology |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 14.4 Kbps |
PC Faxing | Yes |
Fax Machine Features | |
Features | Fax forwarding, automatic redialing, Distinctive Ring Detection (DRD), fax polling |
Document & Media Handling | |
Max Original Size | 216 x 297 mm |
Supported Original Sizes | 216 x 297 mm |
Min Media Size | 76.2 x 127 mm |
Max Media Size | A4/Letter |
Min Media Weight | 60 g/m² |
Max Media Weight | 300 g/m² |
Min Media Weight (lb) | 16 lbs |
Max Media Weight (lb) | 80 lbs |
Supported Media Type | Envelopes, plain paper, cards, recycled paper, photo paper, light-weight paper, glossy paper, matte paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm) |
Borderless Photo Sizes | 216 x 297 mm |
Document & Media Handling Details | Input tray - 100 sheets size: 76.2 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs , Output tray - 25 sheets , ADF - 35 sheets |
Speed Details | Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft , Printing: up to 10 ppm (A4) - B/W (ISO) , Printing: up to 7 ppm (A4) - colour (ISO) , Copying: up to 8 ppm - B/W (ISO) , Copying: up to 4 ppm (A4) - colour (ISO) , Scanning: up to 7 ipm (Letter A) - B/W normal , Scanning: up to 7 ipm (A4) - B/W normal , Scanning: up to 3 ipm (Letter A) - colour normal , Scanning: up to 3 ipm (A4) - colour normal |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B |
Operating System Support | MS Windows 7 (32/64 bits), Windows 10 (32/64-bits), macOS 10.12, macOS 10.13, macOS 10.14, macOS 10.15 |
Software Included | HP Smart App |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Standby | 4 Watt |
Power Consumption Sleep | 1.7 Watt |
Miscellaneous | |
Compliant Standards | FCC Class B certified, FCC CFR47 Part 15, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6, EN 301 489-17 V3.1.1 (2017), CISPR 35, VCCI-CISPR 32:2016, CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 43.25 cm |
Depth | 36.11 cm |
Height | 13.21 cm |
Weight | 6.16 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 47.4 cm |
Shipping Depth | 40.8 cm |
Shipping Height | 21.8 cm |
Shipping Weight | 7.55 kg |
Environmental Parameters | |
Sound Emission | 55 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
