We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Deploy a display designed specifically for clinicians with the HP Healthcare Edition HC270cr. It's built for easy, repeatable sanitization, DICOM Part 14 compliant for viewing medical images, and enhanced with single sign-on authentication support and collaboration tools for telemedicine.
Product Description | HP HC270cr Clinical Review Monitor - Healthcare - LED monitor - 3.7MP - colour - 27" | Device Type | LED-backlit LCD monitor - 3.7MP - colour - 27" | Features | RFID reader, USB 3.0 hub, 720p webcam, dual array microphone | Panel Type | AHVA | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 3000000:1 (dynamic) | Response Time | 12 ms (grey-to-grey) | Input Connectors | HDMI, 2xDisplayPort, VGA, USB-C | Display Position Adjustments | Pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, anti-static | Voltage | AC 120/230 V | Colour | Ceramic white | Dimensions (WxDxH) - with stand | 65.06 cm x 24.69 cm x 55.49 cm | Weight | 8.81 kg | Localisation | English / United Kingdom | Compliant Standards | IEC 60601-1-2, DICOM Part 14, low halogen | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix - 3.7MP - colour |
Diagonal Size | 27" |
Built-in Devices | RFID reader, USB 3.0 hub, 720p webcam, dual array microphone |
Panel Type | AHVA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | BrightView |
Dimensions (WxDxH) | 65.06 cm x 24.69 cm x 55.49 cm - with stand |
Weight | 8.81 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | 2 x DisplayPort , HDMI , VGA , USB-C , USB 3.0 upstream , 2 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+25 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Miscellaneous | |
Cables Included | DisplayPort cable , HDMI cable , VGA cable , USB-C cable , USB-B to USB-A cable |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 65 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 65.06 cm - depth: 24.69 cm - height: 55.49 cm - weight: 8.81 kg , Without stand - width: 65.06 cm - depth: 4.37 cm - height: 41.68 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
