We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Be assured that grayscale and color medical images and patient information are consistent and accurate on every display. The HP Pixel Policy also means you get a screen with zero bright dots, or HP replaces it.
View your medical images and records onscreen with a 24" diagonal IPS display with 1920 x 1200 resolution. Seamlessly work across multiple displays and sources with micro-edge bezels, DisplayPort multi-stream support, and Picture-in-Picture.
Attach your HP Desktop Mini or select HP Thin Client behind the display for an integrated, small footprint solution that's perfect for busy and shared spaces like nurse's or charting stations. Mount on a wall or arm with the VESA pattern.
Product Description | HP HC240 - Healthcare - LED monitor - 24" | Device Type | LED-backlit LCD monitor - 24" | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | 1920 x 1200 at 60 Hz | Pixel Pitch | 0.27 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 8 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | DVI-D, DisplayPort, Mini DisplayPort, HDMI (MHL) | Display Position Adjustments | Pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | White | Dimensions (WxDxH) - with stand | 53.38 cm x 21.01 cm x 52.02 cm | Weight | 5.78 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, CSA, UL, VCCI, C-Tick, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, DICOM Part 14, NFPA 99, MEPS, CECP, EAC, ISC, low halogen, CE/EMC | Manufacturer Warranty | 5-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 75 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | HDCP, DICOM calibrated, Frame Rate Control (FRC), Mercury free, arsenic-free glass, USB 3.0 Fast Charge, 99% sRGB colour gamut |
Colour | White |
Dimensions (WxDxH) | 53.38 cm x 21.01 cm x 52.02 cm - with stand |
Weight | 5.78 kg |
Connectivity | |
Interfaces | DVI-D , DisplayPort , MHL / HDMI , Mini DisplayPort , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream |
Mechanical | |
Tilt Angle | -2/+20 |
Swivel Angle | 45 |
Rotation Angle | 90 |
VESA Mounting Interface | Yes |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support |
Cables Included | 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB 3.0 / USB 2.0 cable - 1.8 m |
Backlight Life | 30,000 hours |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 36 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | HP Support Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.38 cm - depth: 21.01 cm - height: 52.02 cm - weight: 5.78 kg , Without stand - width: 53.38 cm - depth: 4.93 cm - height: 35.11 cm - weight: 3.87 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years - on-site - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
