We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Give your clinicians a security-enhanced display optimized for patient rooms, nurses stations, medical carts, and public areas with the HP Healthcare Edition HC241p. It has an integrated privacy filter and is built for easy, repeatable sanitization.
Product Description | HP HC241p Clinical Review - Healthcare - LED monitor - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class F | Energy Consumption per Year | 33 kWh | Power Consumption (On mode) | 20.6 W | Features | USB 3.0 hub | Panel Type | AHVA | Aspect Ratio | 16:10 | Native Resolution | WUXGA 1920 x 1200 at 60 Hz | Pixel Pitch | 0.27 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 14 ms (grey-to-grey) | Input Connectors | HDMI, VGA, DisplayPort | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | White | Dimensions (WxDxH) - with stand | 56.36 cm x 19.7 cm x 55.16 cm | Weight | 6.87 kg | Localisation | English / United Kingdom | Compliant Standards | Plug and Play, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, CECP, EAC, ISC, low halogen, CE/EMC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Built-in Devices | USB 3.0 hub |
Panel Type | AHVA |
Vertical Refresh Rate | 60 Hz |
Horizontal Refresh Rate | 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Privacy filter, Mercury free, arsenic free |
Colour | White |
Dimensions (WxDxH) | 56.36 cm x 19.7 cm x 55.16 cm - with stand |
Weight | 6.87 kg |
Connectivity | |
Interfaces | DisplayPort (HDCP) , HDMI (HDCP) , VGA , 2 x USB 3.0 downstream , USB 3.0 upstream |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20.6 kWh/1000h |
Power Consumption (Typical) | 25 Watt |
Power Consumption Stand by | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.36 cm - depth: 19.7 cm - height: 55.16 cm - weight: 6.87 kg , Without stand - width: 56.36 cm - depth: 5.24 cm - height: 37.88 cm - weight: 4.74 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
