We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Count on the fast print speeds up to 20 ppm, automatic two-sided printing, and reliable Wi-Fi connectivity. Choose HP+ and get 6 months of Instant Ink and 1 extra year of HP warranty with exclusive use of Original HP Ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
*Choose to activate HP+ at printer set up. Requires ongoing internet connection, set up of an HP account and use of only Original HP Ink or Toner for the life of the printer.
Learn more: hp.com
Product Description | HP Officejet Pro 8025e All-in-One - multifunction printer - colour - HP Instant Ink eligible | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | United Kingdom, Ireland | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 20000 pages | Recommended Monthly Volume | 800 pages | Max Copying Speed | Up to 13 ppm (mono) / up to 7 ppm (colour) | Max Copying Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Printing Speed | Up to 20 ppm (mono) / up to 10 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi | Scanning | 1200 x 1200 dpi | Display | 2.7" | Original Size | 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper | Standard Media Capacity | 225 sheets | Max Media Capacity | 225 sheets | Output Trays Capacity | 60 sheets | Automatic Duplexing | Yes (copying) Yes (printing) Yes (scanning) | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n) | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 46 cm x 34.12 cm x 23.4 cm | Weight | 8.2 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
