HP INK CARTRIDGE 981Y CYAN
£188.30
Delivery:
Standard: 1-3 working days
Key features
  • Avoid wasting time troubleshooting device issues, using consistent, reliable Original HP PageWide cartridges.
  • Count on professional-quality results at high speeds, using Original HP PageWide cartridges.
  • Lock in tremendous value and an impressively low cost per page for high-volume printing.
  • Replace cartridges quickly and correctly with easy-open packaging and simple, fast installation.
  • Stock Status: In Stock
Product codes
Professional-quality colour for an exceptional value – up to 16,000 pages per cartridge at an ultra-low cost per page. Get the results you expect with extra-high-yield cartridges designed and engineered for HP PageWide Enterprise devices.
Print up to 16,000 color pages at a significantly lower cost per page than standard cartridges. Extra-high-yield cartridges lock in the exceptional value your HP PageWide Enterprise printer was built to deliver.
Produce professional-quality documents at speeds your printer was built for. Original HP PageWide cartridges are precisely engineered to match the high-speed performance of HP PageWide Enterprise printers and MFPs and to deliver consistent results.
Get professional-quality pages and enterprise-level performance every day. Protect your investment with Original HP PageWide cartridges specially designed and precisely engineered for HP printers and MFPs—so you can count on fast, consistent results.
Easily replace cartridges in a snap, and tackle high-volume print jobs without interruptions. Original HP PageWide cartridges make printing easy, so work flows smoothly.
Product Description HP 981Y - Extra High Yield - cyan - original - PageWide - ink cartridge
Product Type Ink cartridge
Printing Technology Ink-jet
HP Sub-brand PageWide
Printing Colour Cyan (pigmented)
Capacity 185 ml
Cartridge Yield Extra High Yield
Yield Up to 16000 pages ISO/IEC 24711
Compatible with PageWide Enterprise Color 556dn, 556xh, MFP 586dn, MFP 586f; PageWide Enterprise Color Flow MFP 586z; PageWide Managed Color E55650dn, MFP E58650dn; PageWide Managed Color Flow MFP E58650z
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP INK CARTRIDGE 981Y...
£188.30
