HP Integrated Work Center Stand - Monitor/desktop stand - 17&...
HP Integrated Work Center Stand - Monitor/desktop stand - 17"-2
£70.30
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Enjoy compatibility with a wide range of monitors, including most of the HP Pro and Elite portfolios and an HP Desktop Mini, HP Thin Client or HP Chromebox.
  • Find your best viewing position with adjustable height, tilt, and swivel adjustment settings.
  • Get compatibility with a wide range of monitors, including most of the HP Pro and Elite portfolios. The stylish aesthetic also complements and shows off the HP Desktop Mini, HP Thin Client or HP Chromebox positioned front and center underneath the display.
  • Get the reassurance of a one-year parts replacement limited warranty.
  • Run your display and HP Desktop Mini, HP Thin Client or HP Chromebox cables through the IWC’s guides. Secure the HP Desktop Mini’s power brick out of the way in the brick holder on the back of the stand.
  • Save time and work smarter with easy front access to your platform’s inputs, connectors, and power buttons. Even better, you don’t have to move the entire IWC around during the day to get to them.
  • Type: Stand
  • Stock Status: In Stock
Product codes
Make the most of small work spaces with an HP IWC Desktop Mini/Thin Client that lets you create a compact desktop solution by combining a display with an HP Desktop Mini, HP Thin Client or HP Chromebox and giving you convenient front access to all of its inputs.
Product Description HP Integrated Work Center Stand monitor/desktop stand
Product Type Monitor/desktop stand
Package Content VGA cable, mounting bracket
Colour Black
Dimensions (WxDxH) 41.1 cm x 25.9 cm x 27.4 cm
Weight 2.6 kg
Display Screen Size Compatibility 17"-24"
Features Tilt adjustment, swivel adjustment, adjustable height, HP Quick Release, VESA interface support
Designed For HP 260 G1, 260 G2, LV2011, LV241, t310, t430, t530, t628, V201, V206, V241, Z22, Z23, Z24; Chromebox G2; EliteDesk 705 G1, 705 G3, 800 G1, 800 G2; EliteDisplay E190, E201, E221, E231, E23123, E241; Flexible t520; ProDesk 400 G1, 400 G2, 400 G3, 600 G1, 600 G2, 600 G3; ProDisplay P17, P19, P201, P231
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Integrated Work Cen...
£70.30
