HP Integrated Work Center Stand for Monitor/Desktop
£147.36
Delivery:
Key features
  • Integrates your HP Compaq 6005 Pro, or 8000 Series HP Ultra-slim Desktop PC or an HP Thin Client and most HP 17 to 24-inch (43,18 to 60,96 cm) diagonal LCD monitors, allowing you to conveniently put the entire compact system configuration at your fingertips, saving valuable desktop space and making the most efficient use of space-constrained office environments
  • Cable management clips help keep cables neatly dressed and concealed behind the stand
  • Industry-standard VESA mounting holes enable high or low positioning of the USDT or Thin Client
Product codes
The HP Integrated Work Center Stand is designed to help maximize the use of limited desk space without compromising performance or productivity by accommodating an HP Compaq 6005 Pro, or 8000 Series HP Ultra-slim Desktop PC or an HP Thin Client and most HP 17 to 24-inch (43.18 to 60.96 cm) diagonal LCD monitors (please refer to compatibility in the Quick Spec) with VESA standard mounting brackets.
Product Description HP Integrated Work Center Stand monitor/desktop stand
Product Type Monitor/desktop stand
Package Content VGA cable, mounting bracket
Colour Black, meteorite
Dimensions (WxDxH) 36.19 cm x 25.05 cm x 37.35 cm
Weight 3.1 kg
Features Tilt adjustment, swivel adjustment, adjustable height, HP Quick Release
Designed For HP L2206tm, L2311c, LA1956x, LA2206xc, LE1711, LE1911, LE1911i, LV2011, LV2011q, LV241, t310, t310 G2, t430, t530, t628, V241, V241a, Z22i; EliteDesk 800 G1; EliteDisplay E201, E221, E221c, E231; Flexible t520, t620; ProDesk 600 G3; ProDisplay P191, P19A, P201, P201m, P221, P231
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Integrated Work Cen...
£147.36
