HP LaserJet Enterprise 700 M725z Mono Laser Multifunction Pri...
HP LaserJet Enterprise 700 M725z Mono Laser Multifunction Printer
£4,187.83
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Help conserve resources and meet corporate environmental goals. HP Auto-On/Auto-Off Technology helps reduce energy use.
  • Monitor your devices with industry-leading tools, including HP Web Jetadmin. Help protect data both in transit and at rest.
  • Set a swift pace – use this powerful MFP to keep your work moving. Save time and make your job easier, using HP Quick Sets.
  • Stay focused on work – paper capacity up to 4,600 sheets and high-capacity cartridges limit interruptions.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Output Type: Monochrome
  • Wireless Capability: Wired
  • Technology: Laser
Product codes
Enable large-volume printing on a wide range of paper sizes – up to A3 – with a 4,600-sheet maximum input capacity. Preview and edit scanning jobs; centrally manage printing policies; safeguard sensitive business information.
Product Description HP LaserJet Enterprise MFP M725z - multifunction printer - B/W
Device Type Multifunction printer
Fax Type Plain paper
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 200000 impressions
Recommended Monthly Volume 5000 - 20000 pages
Max Copying Speed Up to 41 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 41 ppm
Max Printing Resolution Up to 1200 x 1200 dpi
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 300 x 300 dpi, 400 x 400 dpi, 204 x 98 dpi, 204 x 196 dpi
Scanning 600 x 600 dpi
Display 8"
Original Size A3 (297 x 420 mm) (max)
Original Type Sheets
Document Feeder Capacity 100 sheets
Media Size 76.2 x 127 mm (min) - 312 x 469.9 mm (max)
Media Type Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper
Standard Media Capacity 2100 sheets
Max Media Capacity 2100 sheets
Bypass Feeder Capacity 100 sheets
Output Trays Capacity 750 sheets
Collator Included
Stacker Included
Stapler Included
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, USB host, USB host (internal)
AirPrint Enabled Yes
Office Machine Features Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH)
Power AC 230 V (50Hz)
Dimensions (WxDxH) 74.5 cm x 68.1 cm x 119.2 cm
Weight 92.35 kg
Environmental Standards ENERGY STAR Qualified, EPEAT Silver
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP LaserJet Enterprise...
£4,187.83
