General |
Device Type |
Multifunction printer |
Copier Type |
Digital |
Fax Type |
Plain paper |
Printing Technology |
Laser - colour |
Monthly Duty Cycle (max) |
120000 impressions |
Recommended Monthly Volume |
2500 - 7500 pages |
Display Diagonal Size |
8.07" |
Display Features |
Touch screen |
Connection Availability |
Yes |
Interface |
USB 2.0, Gigabit LAN, USB host, 2 x USB host (internal) |
AirPrint Enabled |
Yes |
Office Machine Features |
Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, automatic paper sensor, Foreign Interface Harness (FIH) |
Localisation |
English, German, French, Italian, Spanish / Europe |
Memory |
Standard Memory |
1.5 GB |
Max Supported Memory |
1.5 GB |
Copying |
Max Copying Speed |
Up to 30 ppm (mono) / up to 30 ppm (colour) |
Max Copying Resolution |
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) |
Max Document Enlargement |
400% |
Max Document Reduction |
25% |
Maximum Copies |
9999 |
Automatic Duplexing |
Yes |
Copying Features |
Auto colour select, collation copy |
Printing |
Max Printing Resolution |
Max Printing Speed |
Printer Drivers / Emulations |
PCL 6, PostScript 3, PCL 5c, PDF 1.4 |
Image Enhancement Technology |
HP ImageREt 3600 |
Yes |
First Print Out Time B/W |
10.5 sec |
First Print Out Time Colour |
10.5 sec |
Scanning |
Scan Element |
CCD |
Optical Resolution |
600 x 600 dpi |
Grayscale Depth |
8-bit |
Colour Depth |
24-bit |
Fax Machine |
Max Transmission Speed |
33.6 Kbps |
Fax Resolutions |
300 x 300 dpi, 204 x 98 dpi, 204 x 196 dpi |
Total Memory Capacity |
Up to 100 pages |
Fax Printing Resolution |
400 x 400 dpi |
PC Faxing |
Yes |
Fax Machine Features |
Speed Dialing |
100 station(s) |
Broadcast Transmission |
100 stations |
Features |
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, fax polling |
Document & Media Handling |
Min Original Size |
101.6 x 152.4 mm |
Max Original Size |
A3/Ledger (297 x 432 mm) |
Original Type |
Sheets |
Document Feeder Capacity |
100 sheets |
Min Media Size |
76 x 127 mm |
Max Media Size |
A3/Ledger |
Min Media Weight |
49 g/m² |
Max Media Weight |
120 g/m² |
Supported Media Type |
Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, film, heavy-weight paper, card stock |
Supported Media Sizes |
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), Folio (216 x 330 mm), 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 320 x 470 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm) |
Supported Envelope Sizes |
US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm) |
Standard Media Capacity |
3850 sheets |
Bypass Feeder Capacity |
100 sheets |
Output Trays Capacity |
750 sheets |
Document & Media Handling Details |
Stacker / stapler - 500 sheets , Output tray - 250 sheets , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , Input tray - 3500 sheets - Letter A (216 x 279 mm) weight: 60 g/m² - 120 g/m² , ADF - 100 sheets size: 101.6 x 152.4 mm - A3/Ledger (297 x 432 mm) |
Speed Details |
Printing: up to 30 ppm (A4) - B/W normal , Printing: up to 30 ppm (A4) - colour normal , Copying: up to 30 ppm (A4) - B/W normal , Copying: up to 30 ppm (A4) - colour normal , Scanning: up to 30 ppm (A4) - B/W normal , Scanning: up to 30 ppm (A4) - colour normal |
Finishing Equipment |
Collator |
Included |
Stacker |
Included |
Stapler |
Included |
Connections |
Interfaces |
1 x USB 2.0 , 1 x USB host , 2 x USB host (internal) , 1 x Gigabit LAN |
Operating System Support |
UNIX, Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8 |
Software Included |
Drivers & Utilities |
Power |
Voltage Required |
AC 230 V (50/60Hz) |
Power Consumption Operational |
703 Watt |
Power Consumption Standby |
85 Watt |
Power Consumption Sleep |
14.8 Watt |
Miscellaneous |
Included Accessories |
Phone cable |
Consumables Included |
1 x Cartridge (black) - up to 13500 pages , 1 x Cartridge (cyan) - up to 16000 pages , 1 x Cartridge (magenta) - up to 16000 pages , 1 x Cartridge (yellow) - up to 16000 pages |
Compliant Standards |
FCC Class A certified, UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008, GB 17625.1-2003 EMC |
Environmental Standards |
EPEAT Compliant |
EPEAT Silver |
ENERGY STAR Certified |
Yes |
Dimensions & Weight |
Width |
74.5 cm |
Depth |
66.8 cm |
Height |
119.8 cm |
Weight |
116.3 kg |
Dimensions & Weight (Shipping) |
Shipping Width |
85.6 cm |
Shipping Depth |
76 cm |
Shipping Height |
155.3 cm |
Shipping Weight |
135.6 kg |
Environmental Parameters |
Sound Emission |
53 dBA (operating) |
Min Operating Temperature |
15 °C |
Max Operating Temperature |
27 °C |
Humidity Range Operating |
10 - 70% |
