HP Laserjet Enterprise Flow M632z Mono Laser 61ppm Multifunct...
HP Laserjet Enterprise Flow M632z Mono Laser 61ppm Multifunction Printer
£4,198.48
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Help workgroups capture every page easily and detect potential errors or missed pages – every time.
  • Produce sharp text, bold blacks, and crisp graphics with precision black toner.
  • Speed through tasks and save paper. Print two-sided documents nearly as fast as single-sided.
  • With HP Sure Start, each printer regularly checks its operating code and repairs itself from attempted hacks.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Output Type: Monochrome
  • Technology: Laser
  • Max Print Speed: 61ppm
Product codes
This HP LaserJet MFP with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
Product Description HP LaserJet Enterprise Flow MFP M632z - multifunction printer - B/W
Device Type Multifunction printer
Fax Type Plain paper
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 300000 pages
Recommended Monthly Volume 5000 - 30000 pages
Max Copying Speed Up to 61 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 61 ppm
Max Printing Resolution Up to 1200 x 1200 dpi
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
Scanning 600 x 600 dpi
Display 8"
Original Size 216 x 863 mm (max)
Original Type Sheets
Document Feeder Capacity 150 sheets
Media Size 76 x 127 mm (min) - 216 x 863 mm (max)
Media Type Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
Standard Media Capacity 3200 sheets
Max Media Capacity 3750 sheets
Bypass Feeder Capacity 100 sheets
Output Trays Capacity 1000 sheets
Stacker Included
Stapler Included
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, Instant-on Technology, scan to SharePoint, scan to OCR, HP Auto-On/Auto-Off Technology, Instant-on Copy
Power AC 230 V (50Hz)
Dimensions (WxDxH) 66.1 cm x 65.8 cm x 123.4 cm
Weight 64.3 kg
Environmental Standards ENERGY STAR Qualified, Blue Angel
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Laserjet Enterprise...
£4,198.48
