Finish tasks faster with a printer that starts right away and helps conserve energy. Multi-level device security helps protect from threats. Original HP Toner cartridges with JetIntelligence and this printer produce more high-quality pages.
HP LaserJet Enterprise M506dn - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
11.8 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 43 ppm - black normal - A4 (210 x 297 mm) , Up to 34 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 65 ppm - black draft - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
1.2 GHz
RAM Installed (Max)
512 MB (1.5 GB)
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, punched paper, preprinted paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 7500 pages
Print server
Printer Features
Instant-on Technology
AC 230V
UNIX, Microsoft Windows Server 2003 Standard Edition SP1, Microsoft Windows Server 2003 Enterprise Edition SP1, Microsoft Windows Server 2003 R2 Enterprise Edition SP2, Microsoft Windows Server 2003 R2 Standard Edition SP2, Microsoft Windows Server 2003 Enterprise Edition SP2, Microsoft Windows Server 2003 Standard Edition SP2, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows Server 2003 R2 Enterprise Edition SP1, Microsoft Windows Server 2003 R2 Standard Edition SP1, Ubuntu 11.10, Ubuntu 12.04, openSUSE 12.2, Apple MacOS X 10.8, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Microsoft Windows Server 2008 Standard and Enterprise SP2 (64-bit), Microsoft Windows Server 2008 R2 Standard and Enterprise Edition SP1 (64-bit), Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Windows Server 2008 Standard and Enterprise SP2 (32-bit), Microsoft Windows 7 / 8 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
1 year warranty
41.8 cm x 37.6 cm x 29.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD, numeric key pad
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5.9 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 1.5 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 199 g/m²
650 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 6000 pages
CISPR 22 Class A, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EMC 2004/108/EC, EN 55024:2010, EN 55022:2010 Class A
Power supply - internal
AC 230V
Frequency Required
50 Hz
741.98 Watt
Power Consumption Stand by
13.72 Watt
Power Consumption Sleep
2.51 Watt
Software Included
Drivers & Utilities
