This HP LaserJet Printer with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
Product Description | HP LaserJet Enterprise M607dn - printer - monochrome - laser | Printer Type | Workgroup printer - laser - monochrome | Weight | 21.6 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), RA4 (215 x 305 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 52 ppm - B/W - A4 (210 x 297 mm) , Up to 55 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 43 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 45 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 80 ppm - B/W duplex - A5 (148 x 210 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Image Enhancement Technology | HP FastRes 1200 | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, USB 2.0 host | AirPrint Enabled | Yes | Preview Screen Size | 2.7" | Processor | 1.2 GHz | RAM Installed (Max) | 512 MB (1.5 GB) - DDR3 SDRAM - DIMM 90-pin | Language Simulation | PCL 5, PostScript 3, PCL 6, PDF 1.7 | Media Type | Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper | Total Media Capacity | 650 sheets | Media Handling | 100-sheet multipurpose tray, 550-sheet input tray | Monthly Duty Cycle (max) | 250000 pages | Recommended Monthly Volume | 5000 - 20000 pages | Networking | Print server | Printer Features | Hardware integration pocket, Instant-on Technology, Auto Power On, Auto Power Off, JetIntelligence Cartridge Technology | Power | AC 230V | System Requirements | UNIX, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Novell Open Enterprise Server 2.0, Citrix MetaFrame XP Presentation Server, Citrix MetaFrame Presentation Server 3.0, Citrix Presentation Server 4.0, Android, Microsoft Windows Server 2003 R2 (32/64-bits), Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2008 R2 x64 Edition SP1, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Microsoft Windows Vista Business 32-bit Edition, Citrix XenApp 5, Citrix XenApp 6, Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Vista Enterprise 32-bit Edition, Microsoft Windows Vista Home Premium 32-bit Edition, Citrix XenApp 6.5, Windows 8.1 (32/64 bits), Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple OS X 10.10 Yosemite, Citrix XenDesktop 5.6, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit), Citrix XenDesktop 5.6 (32/64 bits), Novell NetWare 6.5 SP8, Ubuntu Linux 14.04, Apple OS X 10.11 El Capitan, Citrix XenApp 7.5, Citrix XenDesktop 7, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS 10.12 Sierra, Linux Mint 17.2, Linux Mint 17.3, Microsoft Windows Server 2003 R2 (32/64-bits) SP2, SUSE Linux 13.2, Apple macOS 10.12, Linux Mint 18, SUSE Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Linux Fedora 23, Linux Fedora 24, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6 | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 43.1 cm x 46.6 cm x 38 cm |
General | |
Printer | |
Built-in Devices | 2.7 inch QVGA LCD display |
Connectivity Technology | Wired |
PostScript Support | Standard |
Fonts Included | 105 x TrueType , 92 x PostScript 3 |
Processor | |
RAM | |
RAM Installed (Max) | 512 MB / 1.5 GB (max) |
Technology / Form Factor | DDR3 SDRAM - DIMM 90-pin |
Slots Qty | 1 |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 99 x 148 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), RA4 (215 x 305 mm) |
Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm) |
Media Weight | 60 g/m² - 199 g/m² |
Media Feeders | Input tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , Input tray: 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² |
Max Media Capacity | 4400 sheets |
Output Trays Capacity | 500 sheets |
Duty Cycle | |
Networking | |
Network Controller Name | HP Jetdirect |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, IPP 2.0, SLP |
Security Protocols & Features | Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP, Secure Erase |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 , 2 x USB 2.0 host , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Compliant Standards | UL, cUL, GS, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EMC 2004/108/EC, 21 CFR 1040.10, 21 CFR 1040.11, EN 55024:2010, EN 55022:2010 Class A, ICES-003 issue 5 Class A, CISPR 22:2008, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, FCC CFR47 Part 15 B Class A, IEC 60825-1:2007 Class 1, EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013 |
Security Slot Type | Kensington security slot |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 230V |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 780 Watt |
Power Consumption Stand by | 15.3 Watt |
Power Consumption Sleep | 3.1 Watt |
Software / System Requirements | |
Software Included | HP Software Installer, HP Software Uninstaller, HP Device Experience (DXP), HP Connected |
OS Required | UNIX, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Novell Open Enterprise Server 2.0, Citrix MetaFrame XP Presentation Server, Citrix MetaFrame Presentation Server 3.0, Citrix Presentation Server 4.0, Android, Microsoft Windows Server 2003 R2 (32/64-bits), Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2008 R2 x64 Edition SP1, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Microsoft Windows Vista Business 32-bit Edition, Citrix XenApp 5, Citrix XenApp 6, Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Vista Enterprise 32-bit Edition, Microsoft Windows Vista Home Premium 32-bit Edition, Citrix XenApp 6.5, Windows 8.1 (32/64 bits), Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple OS X 10.10 Yosemite, Citrix XenDesktop 5.6, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit), Citrix XenDesktop 5.6 (32/64 bits), Novell NetWare 6.5 SP8, Ubuntu Linux 14.04, Apple OS X 10.11 El Capitan, Citrix XenApp 7.5, Citrix XenDesktop 7, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS 10.12 Sierra, Linux Mint 17.2, Linux Mint 17.3, Microsoft Windows Server 2003 R2 (32/64-bits) SP2, SUSE Linux 13.2, Apple macOS 10.12, Linux Mint 18, SUSE Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Linux Fedora 23, Linux Fedora 24, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6 |
Environmental Standards | |
Blue Angel | Yes |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 32.5 °C |
Humidity Range Operating | 10 - 90% |
Sound Emission (Operating) | 55 dBA |
Dimensions & Weight | |
Width | 43.1 cm |
Depth | 46.6 cm |
Height | 38 cm |
Weight | 21.6 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 59.7 cm |
Depth (Shipping) | 53.9 cm |
Height (Shipping) | 49.7 cm |
Weight (Shipping) | 27.2 kg |
