This HP LaserJet Printer with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
HP LaserJet Enterprise M608n - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
21.6 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 100 ppm - B/W - A5 (148 x 210 mm) , Up to 61 ppm - B/W - A4 (210 x 297 mm) , Up to 65 ppm - black normal - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Image Enhancement Technology
HP FastRes 1200
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Preview Screen Size
2.7"
1.2 GHz
RAM Installed (Max)
512 MB (1.5 GB) - DDR3 SDRAM - DIMM 90-pin
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, light-weight paper, punched paper, preprinted paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
275000 pages
Recommended Monthly Volume
5000 - 25000 pages
Print server
Printer Features
Hardware integration pocket, Instant-on Technology, Auto Power On, Auto Power Off
AC 230V
UNIX, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Novell Open Enterprise Server 2.0, Citrix MetaFrame XP Presentation Server, Citrix MetaFrame Presentation Server 3.0, Citrix Presentation Server 4.0, Android, Microsoft Windows Server 2003 R2 (32/64-bits), Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2008 R2 x64 Edition SP1, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Microsoft Windows Vista Business 32-bit Edition, Citrix XenApp 5, Citrix XenApp 6, Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Vista Enterprise 32-bit Edition, Microsoft Windows Vista Home Premium 32-bit Edition, Citrix XenApp 6.5, Windows 8.1 (32/64 bits), Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple OS X 10.10 Yosemite, Citrix XenDesktop 5.6, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit), Citrix XenDesktop 5.6 (32/64 bits), Novell NetWare 6.5 SP8, Ubuntu Linux 14.04, Apple OS X 10.11 El Capitan, Citrix XenApp 7.5, Citrix XenDesktop 7, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS 10.12 Sierra, Linux Mint 17.2, Linux Mint 17.3, Microsoft Windows Server 2003 R2 (32/64-bits) SP2, SUSE Linux 13.2, Apple macOS 10.12, Linux Mint 18, SUSE Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Linux Fedora 23, Linux Fedora 24, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6
1 year warranty
43.1 cm x 46.6 cm x 38 cm
Printer Type
Printer
Print Speed
Preview Screen Size
2.7"
Wired
AirPrint Enabled
1200 x 1200 dpi
HP FastRes 1200
PostScript Support
Standard
First Print Out Time B/W
7.9 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 1.5 GB (max)
Technology / Form Factor
Slots Qty
2
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, 99 x 148 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 199 g/m²
650 sheets
Media Feeders
1 x manual - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 190 g/m² , 1 x manual - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Kerberos, LDAP, Apple Bonjour, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security lock slot (cable lock sold separately), collation
UL, cUL, GS, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, EN 55024:2010, EN 55022:2010 Class A, ICES-003 issue 5 Class A, CISPR 22:2008, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, FCC CFR47 Part 15 B Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IEC60950-1:2005+A1:2009+A2:2013, IEC 60825-1:2007 Class 1
Security Slot Type
Kensington security slot
Power supply - internal
AC 230V
Frequency Required
50 Hz
780 Watt
Power Consumption Sleep
3.1 Watt
Software Included
Drivers & Utilities, HP SureSupply, HP Device Experience (DXP)
Environmental Standards
Blue Angel
Limited warranty - 1 year
15 °C
32.5 °C
10 - 90%
Sound Emission (Operating)
55 dBA
43.1 cm
46.6 cm
38 cm
21.6 kg
Width (Shipping)
59.7 cm
Depth (Shipping)
49.7 cm
Height (Shipping)
53.9 cm
Weight (Shipping)
27.2 kg
Customer reviews
