We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This HP LaserJet Printer with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
Product Description | HP LaserJet Enterprise M609x - printer - B/W - laser | Printer Type | Workgroup printer - laser - B/W | Weight | 26.3 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), RA4 (215 x 305 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 71 ppm - B/W - A4 (210 x 297 mm) , Up to 75 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 58 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 62 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Image Enhancement Technology | HP FastRes 1200 | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, Bluetooth, Wi-Fi(n), USB 2.0 host | AirPrint Enabled | Yes | Preview Screen Size | 4.3" | Processor | 1.2 GHz | RAM Installed (Max) | 512 MB (1.5 GB) - DDR3 SDRAM - DIMM 90-pin | Language Simulation | PCL 5, PostScript 3, PCL 6, PDF 1.7 | Media Type | Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, light-weight paper, punched paper, preprinted paper | Total Media Capacity | 1200 sheets | Media Handling | 100-sheet multipurpose tray, 2x 550-sheet input trays | Monthly Duty Cycle (max) | 300000 pages | Recommended Monthly Volume | 5000 - 30000 pages | Networking | Print server | Printer Features | Hardware integration pocket, Instant-on Technology, JetIntelligence Cartridge Technology | Power | AC 230V | System Requirements | UNIX, Microsoft Windows Vista (32-bit versions), Android, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple OS X 10.10 Yosemite, Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Ubuntu Linux 14.04, Apple OS X 10.11 El Capitan, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS Sierra 10.12 or later, Linux Mint 17.2, Linux Mint 17.3, SUSE Linux 13.2, Linux Mint 18, SUSE Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10 | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 43.1 cm x 46.6 cm x 50.5 cm |
General | |
Printer Type | Workgroup printer - laser - monochrome |
Printer | |
Built-in Devices | 4.3 inch LCD touch screen |
Connectivity Technology | Wireless |
PostScript Support | Standard |
Fonts Included | 105 x TrueType , 92 x PostScript 3 |
Processor | |
RAM | |
RAM Installed (Max) | 512 MB / 1.5 GB (max) |
Technology / Form Factor | DDR3 SDRAM - DIMM 90-pin |
Slots Qty | 1 |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, 215.9 x 330.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm) |
Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm) |
Media Weight | 60 g/m² - 199 g/m² |
Media Feeders | 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , 2 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² |
Max Media Capacity | 4400 sheets |
Output Trays Capacity | 500 sheets |
Duty Cycle | |
Networking | |
Network Controller Name | HP Jetdirect |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, IPP 2.0, SLP |
Security Protocols & Features | Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 , 2 x USB 2.0 host , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Compliant Standards | FCC Class A certified, UL, cUL, GS, FCC CFR47 Part 15, Directive 2006/95/EC, EN 62479:2010, 21 CFR 1040.10, 21 CFR 1040.11, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, IEC 60825-1:2007 Class 1 |
Security Slot Type | Kensington security slot |
Power | |
Power Device | Power supply - internal |
Voltage Required | AC 230V |
Frequency Required | 50/60 Hz |
Software / System Requirements | |
OS Required | UNIX, Microsoft Windows Vista (32-bit versions), Android, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple OS X 10.10 Yosemite, Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Ubuntu Linux 14.04, Apple OS X 10.11 El Capitan, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS Sierra 10.12 or later, Linux Mint 17.2, Linux Mint 17.3, SUSE Linux 13.2, Linux Mint 18, SUSE Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10 |
Environmental Standards | |
Blue Angel | Yes |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 32.5 °C |
Humidity Range Operating | 10 - 90% |
Sound Emission (Operating) | 55 dBA |
Dimensions & Weight | |
Width | 43.1 cm |
Depth | 46.6 cm |
Height | 50.5 cm |
Weight | 26.3 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 76.2 cm |
Depth (Shipping) | 59.3 cm |
Height (Shipping) | 51.1 cm |
Weight (Shipping) | 33.8 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
