General |
Device Type |
Multifunction printer |
Fax Type |
Plain paper |
Printing Technology |
Laser - monochrome |
Monthly Duty Cycle (max) |
300000 pages |
Recommended Monthly Volume |
5000 - 30000 pages |
Display Diagonal Size |
8" |
Display Features |
Touch screen |
Connection Availability |
Yes |
Interface |
USB 2.0, Gigabit LAN, Bluetooth, Wi-Fi(n), USB 2.0 host |
AirPrint Enabled |
Yes |
Office Machine Features |
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, HP High-Performance Secure Hard Disk, Instant-on Technology, scan to SharePoint, scan to OCR, HP Auto-On/Auto-Off Technology, Instant-on Copy |
Localisation |
English, German, French, Italian, Spanish / Europe |
Memory |
Standard Memory |
2 GB |
Max Supported Memory |
2.5 GB |
Hard Disk Drive |
320 GB |
Supported Flash Memory |
USB flash drive |
Copying |
Max Copying Speed |
Up to 52 ppm |
Max Copying Resolution |
Up to 600 x 600 dpi |
Max Document Enlargement |
400% |
Max Document Reduction |
25% |
Maximum Copies |
9999 |
Automatic Duplexing |
Yes |
Copying Features |
ID Card Copy, Manual Color Adjustment, collation copy, Job Build, Edge Erase, blank page skipping, Book Copy |
Printing |
Max Printing Resolution |
Up to 1200 x 1200 dpi |
Max Printing Speed |
Up to 52 ppm |
Printer Drivers / Emulations |
PCL 6, PostScript 3, PDF 1.7, PCL 5 |
Image Enhancement Technology |
HP FastRes 1200 |
Yes |
Scanning |
Scan Element |
CCD |
Yes |
Optical Resolution |
600 x 600 dpi |
Grayscale Depth |
8-bit |
Colour Depth |
24-bit |
Fax Machine |
Max Transmission Speed |
33.6 Kbps |
Fax Resolutions |
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi |
Total Memory Capacity |
Up to 500 pages |
Fax Printing Resolution |
400 x 400 dpi |
PC Faxing |
Yes |
Fax Machine Features |
Speed Dialing |
1000 station(s) |
Remote Fax Retrieval (Polling) |
Yes |
Features |
Fax forwarding, automatic redialing, junk fax barrier, LAN fax, auto reduction, fax polling, fax archiving |
Document & Media Handling |
Max Original Size |
216 x 863 mm |
Original Type |
Sheets |
Document Feeder Capacity |
150 sheets |
Min Media Size |
76 x 127 mm |
Max Media Size |
A4/Legal |
Min Media Weight |
45 g/m² |
Max Media Weight |
199 g/m² |
Supported Media Type |
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper |
Supported Media Sizes |
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 216 x 863 mm, 99 x 148 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), RA4 (215 x 305 mm) |
Supported Envelope Sizes |
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm) |
Standard Media Capacity |
2300 sheets |
Max Media Capacity |
3850 sheets |
Bypass Feeder Capacity |
100 sheets |
Output Trays Capacity |
1000 sheets |
Document & Media Handling Details |
ADF - 150 sheets size: 76 x 127 mm - 216 x 863 mm weight: 45 g/m² - 199 g/m² , Input tray - 550 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 3 x input tray - 550 sheets , Output tray - 500 sheets , Stacker / stapler - 500 sheets , Bypass tray - 100 sheets |
Speed Details |
Printing: up to 80 ppm (A5) - B/W normal , Printing: up to 52 ppm (A4) - B/W normal , Printing: up to 43 ppm (A4) - B/W duplex , Copying: up to 52 ppm (A4) - B/W normal , Copying: up to 43 ppm (A4) - B/W duplex , Copying: up to 55 ppm (Letter A) - B/W normal , Copying: up to 45 ppm (Letter A) - B/W duplex , Printing: up to 45 ppm (Letter A) - B/W duplex , Printing: up to 55 ppm (Letter A) - B/W normal |
Finishing Equipment |
Stacker |
Included |
Stapler |
Included |
Connections |
Interfaces |
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A , 1 x modem - RJ-11 |
Security Protocols & Features |
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP |
Operating System Support |
UNIX, Novell NetWare 6.5, MS Windows Server 2008 R2, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows Server 2012, Novell Open Enterprise Server, Android, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Boss 5.0, Debian Linux 7.x, Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2, Debian Linux 8.0, Novell Open Enterprise Server 11, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24 |
Software Included |
Drivers & Utilities, HP Web Jetadmin, HP Device Experience (DXP), HP Connected |
Power |
Voltage Required |
AC 230 V (50Hz) |
Miscellaneous |
Compliant Standards |
UL, cUL, GS, EMC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, ETSI ES203 021, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008, EN 60950-1:2006+A1:2010+A2:2013+A11:2009+A12:2011, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, R&TTE Directive 1999/5/EC, IEC 60825-1:2007 Class 1 |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - 1 year - on-site - response time: next business day |
Dimensions & Weight |
Width |
66.1 cm |
Depth |
65.8 cm |
Height |
123.4 cm |
Weight |
62.5 kg |
Dimensions & Weight (Shipping) |
Shipping Width |
85.6 cm |
Shipping Depth |
76 cm |
Shipping Height |
166 cm |
Shipping Weight |
86.6 kg |
Environmental Parameters |
Sound Emission |
59 dBA (operating) |
Min Operating Temperature |
15 °C |
Max Operating Temperature |
27 °C |
Humidity Range Operating |
10 - 80% |
