HP LaserJet M527DNM
£1,192.00
Delivery:
Key features
  • Accelerate your work and use less energy
  • Perfect security and management
  • More pages, performance, and protection
Product codes
Finish tasks faster with an MFP that starts right away and helps conserve energy. Multi-level device security helps protect from threats. This MFP is designed for SMBs and small workteams in larger companies, delivering enhanced productivity, simplified workflows and reduced costs.
Don’t wait for documents. Print your first page in as few as 8.7 seconds from energy-efficient sleep mode and 5.7 seconds from ready.
Print two-sided documents without sacrificing performance slowdowns for duplexing and let high-volume jobs handle themselves with a 2,300-sheet maximum input capacity.
Scan two-sided documents in a single pass with super-fast scan speeds. HP EveryPage allows employees to scan without worry, detect potential errors or missed pages on the spot and save time with the advanced workflow features with the Flow MFP M527c.
This MFP leads its class in low energy use – thanks to its innovative design and toner technology.
Unparalleled fleet security and management
Embedded features detect security threats and heal your MFP, protecting it from boot up to shutdown.
Protect sensitive data stored on the MFP and in transit, using embedded and optional security features.
Protect sensitive business data with embedded and optional HP JetAdvantage Security Solutions.
Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.
More. Pages, Performance, and Protection.
Produce sharp text, bold blacks, and crisp graphics with precision black toner.
Get more. Original HP Toner with JetIntelligence delivers more pages per cartridge than predecessors.
Help ensure the Original HP quality you paid for with anti-fraud and cartridge authentication technology.
Print right away with a preinstalled toner cartridge. Replace it with an optional high-yield cartridge.
Stay connected with secure mobile printing options
Use optional, 128-bit encrypted wireless direct printing from mobile devices – no network needed.
Add the option to print with a touch of your NFC-enabled mobile device to this printer – no network needed.
Easily access, print, and share resources with Ethernet and optional wireless networking.
Product Description HP LaserJet Managed MFP M527dnm - multifunction printer - B/W
Device Type Multifunction printer
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 150000 pages
Recommended Monthly Volume 2000 - 15000 pages
Max Copying Speed Up to 43 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 43 ppm
Max Printing Resolution Up to 1200 x 1200 dpi
Scanning 600 dpi
Display 8"
Original Size 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 100 sheets
Media Size 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, cards, labels, recycled paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
Standard Media Capacity 650 sheets
Max Media Capacity 2300 sheets
Bypass Feeder Capacity 100 sheets
Output Trays Capacity 250 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH), automatic cutter, security lock slot
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 48.2 cm x 49.6 cm x 49.7 cm
Weight 21.9 kg
Environmental Standards ENERGY STAR Qualified, Blue Angel
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP LaserJet M527DNM
£1,192.00
