HP LaserJet Pro M130fn Multi-Function Printer
£171.25
Delivery:
Standard: 1-3 working days
Key features
  • Print from iPhone® and iPad® with AirPrint®, which automatically scales jobs to the correct paper size.
  • Print, scan, copy, and fax with HP’s smallest LaserJet MFP – designed to fit into tight workspaces.
  • Produce sharp text, bold blacks, and crisp graphics with precision black toner.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Technology: Laser
  • Max Paper Size: Legal (216 x 356 mm)
  • Stock Status: In Stock
Product codes
Keep things simple with HP's smallest LaserJet MFP – powered by JetIntelligence Toner cartridges. Print professional documents from a range of mobile devices, plus scan, copy, fax, and help save energy with an MFP designed for efficiency.
HP LaserJet Pro MFP M130fn - multifunction printer
  • Device Type: Fax / copier / printer / scanner
  • Fax Type: Plain paper
  • Max Copying Resolution: Up to 600 x 600 dpi
  • Max Printing Resolution: Up to 600 x 1200 dpi
  • Original Type: Sheets
  • PC Connection Availability: Yes
  • PC Connection: USB 2.0, Wi-Fi(n)
  • AirPrint Enabled: Yes
  • Power: ( 50/60Hz )
  • Environmental Standards ENERGY STAR Qualified
Product Description HP LaserJet Pro MFP M130fn - multifunction printer - B/W
Device Type Multifunction printer
Fax Type Plain paper
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 10000 pages
Recommended Monthly Volume 150 - 1500 pages
Max Copying Speed Up to 23 ppm
Max Copying Resolution Up to 600 x 400 dpi
Max Printing Speed Up to 23 ppm
Max Printing Resolution Up to 1200 dpi
Fax Resolutions 203 x 98 dpi, 300 x 300 dpi
Scanning 1200 x 1200 dpi
Original Size 148.6 x 210.1 mm (min) - 215.9 x 297.2 mm (max)
Original Type Sheets
Document Feeder Capacity 35 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Media Type Envelopes, plain paper, labels, photo paper, vellum paper, card stock, postcards
Standard Media Capacity 150 sheets
Output Trays Capacity 100 sheets
Connection Availability Yes
Interface USB 2.0, LAN
AirPrint Enabled Yes
Office Machine Features Instant-on Technology, Mobile Printing, JetIntelligence Cartridge Technology
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 41.5 cm x 28.8 cm x 27.9 cm
Weight 7.6 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP LaserJet Pro M130fn...
£171.25
