HP LaserJet Pro M521dn Mono Laser Multifunction Printer
£671.84
Delivery:
Standard: 1-3 working days
Key features
  • Easily complete a range of print, copy, scan and fax tasks. Go from zero to done, right at the MFP.
  • Enjoy unparalleled flexibility: print from your smartphone or tablet from virtually anywhere.
  • Help reduce energy and conserves resources. Use HP Instant-on Copy and HP Auto-On/Auto-Off Technology.
  • Maintain peak performance with fast print speeds of up to 40 ppm . Rely on a robust recommended monthly page volume of 2000 to 6000 pages.
Product codes
Finish jobs faster, produce high-quality documents, and make scanning and sharing simple. Get set up and connected quickly. Send quick commands from an intuitive colour touchscreen. Easily conserve resources and recycle used cartridges.
Product Description HP LaserJet Pro MFP M521dn - multifunction printer - B/W
Device Type Multifunction printer
Fax Type Plain paper
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 75000 impressions
Recommended Monthly Volume 2000 - 6000 pages
Max Copying Speed Up to 40 ppm
Max Copying Resolution Up to 300 x 300 dpi
Max Printing Speed Up to 40 ppm
Max Printing Resolution Up to 1200 x 1200 dpi
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 203 x 98 dpi, 300 x 300 dpi
Scanning 1200 x 1200 dpi
Display 3.5"
Original Size Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, card stock
Standard Media Capacity 600 sheets
Max Media Capacity 1100 sheets
Bypass Feeder Capacity 100 sheets
Output Trays Capacity 350 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, USB host
AirPrint Enabled Yes
Office Machine Features Document send function, save to USB flash drive, scan to e-mail, save to network folder, security lock slot
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 46.5 cm x 46.5 cm x 50.8 cm
Weight 22.3 kg
Environmental Standards ENERGY STAR Qualified, EPEAT Silver
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP LaserJet Pro M521dn...
£671.84
