HP LaserJet Pro MFP M227sdn
£219.02
Delivery:
Key features
  • Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.
  • Print from iPhone® and iPad® with AirPrint®, which automatically scales jobs to the correct paper size.
  • Print, scan, copy, and fax with a compact multifunction laser printer that fits into tight workspaces.
  • Produce sharp text, bold blacks, and crisp graphics with precision black toner.
Product codes
HP Color LaserJet Pro MFP M277dw Colour Laser - Fax / copier / printer / scanner
  • Print, scan, copy, with one compact device
  • Fast two-sided printing built-in
  • Fast FPOT from ready mode
  • HP Auto-On/Auto-Off Technology
  • 6.9 cm touchscreen
Product Description HP LaserJet Pro MFP M227sdn - multifunction printer - B/W
Device Type Multifunction printer
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 30000 pages
Recommended Monthly Volume 250 - 2500 pages
Max Copying Speed Up to 28 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 28 ppm
Max Printing Resolution Up to 1200 x 1200 dpi
Scanning 1200 x 1200 dpi
Original Size Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 35 sheets
Media Size 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper, light-weight paper, preprinted paper, postcards
Standard Media Capacity 250 sheets
Max Media Capacity 250 sheets
Bypass Feeder Capacity 10 sheets
Output Trays Capacity 150 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB 2.0, LAN
AirPrint Enabled Yes
Office Machine Features Instant-on Technology
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 40.3 cm x 40.74 cm x 31.15 cm
Weight 9.4 kg
Environmental Standards ENERGY STAR Qualified, Blue Angel
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: CBKF 042041
£85.09
product
Ref: CBKF 042041
Accessories
Packaging
Functional
Software
Manuals
£85.09
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP LaserJet Pro MFP M2...
£219.02
