HP LaserJet Pro MFP M26nw
Key features
  • Easily access, print, and share resources with Ethernet and wireless networking.
  • Stay productive with print speeds up to 18 pages per minute.
  • Time after time, count on documents with sharp black text from the industry leader in laser printing.
Product codes
Print, scan and copy with proven reliability using the cheapest compact wireless laser multifunction printer from HP. Achieve professional quality and performance you expect.
Outstanding reliable quality without compromise
Easily print high-quality documents and with the reliability you expect from the leader in laser printing. Print directly from the start with a pre-installed cassette and an intuitive LED panel. HP Auto-On / Auto-Off technology helps to save energy.
Maximum productivity for business in compact format
Stay productive. Quickly and easily print, scan and copy documents with an efficient, compact laser multifunction printer designed to fit on small workspaces. This multifunction printer from HP provides high-quality results with HP toner cartridges.
The well-connected multifunction printer to match your work style
Provides consistent results that you can trust. Manage jobs from your mobile device, with or without a network. With mobile printing options, you can produce high-quality printing from virtually anywhere.
Product Description HP LaserJet Pro MFP M26nw - multifunction printer - B/W
Device Type Multifunction printer
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 5000 pages
Recommended Monthly Volume 100 - 1000 pages
Max Copying Speed Up to 18 ppm
Max Copying Resolution Up to 600 x 600 dpi
Max Printing Speed Up to 18 ppm
Max Printing Resolution Up to 1200 dpi
Scanning 1200 dpi
Original Size 216 x 297 mm (max)
Original Type Sheets
Media Size 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, cards, labels
Standard Media Capacity 150 sheets
Output Trays Capacity 100 sheets
Connection Availability Yes
Interface USB 2.0, LAN
Office Machine Features Security lock slot
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 42 cm x 26.6 cm x 25.4 cm
Weight 8.3 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
