Outstanding visual clarity for graphic intensive users demanding top-end features and performance.
| Product Description | HP LP2065 - LCD monitor - 20.1" | Device Type | LCD monitor - 20.1" | Features | USB Hub | Native Resolution | 1600 x 1200 at 75 Hz | Pixel Pitch | 0.255 mm | Brightness | 300 cd/m² | Contrast Ratio | 800:1 | Response Time | 8 ms | Colour Support | 16.7 million colours | Input Connectors | 2xDVI-I | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare, anti-static | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44.3 cm x 22 cm x 42.5 cm | Weight | 9.2 kg | Localisation | English / United Kingdom | Microsoft Certification | Certified for Windows Vista | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Compliant Standards | Plug and Play, MPR II, CSA, UL, TUV, VCCI, BSMI, PC 99, GS, ISO 13406-2, NOM, CCC, TUV Ergo, MIC, FCC | Manufacturer Warranty | 3-year warranty |
General | |
| Display Type | LCD monitor / TFT active matrix |
| Diagonal Size | 20.1" |
| Viewable Size | 20.1" |
| Built-in Devices | USB Hub |
| Vertical Refresh Rate | 85 Hz |
| Horizontal Refresh Rate | 94 kHz |
| Video Bandwidth | 202 MHz |
| Horizontal Viewing Angle | 178 |
| Vertical Viewing Angle | 178 |
| Colour Temperature | 6500K |
| Controls & Adjustments | Brightness, contrast, input select, colour temperature, phase, clock |
| Weight | 9.2 kg |
Connectivity | |
| Interfaces | 2 x DVI-I - 24+5 pin combined DVI , 4 x USB 2.0 downstream - 4 pin USB Type A , 1 x USB 2.0 upstream |
Mechanical | |
| VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
| Features | Security lock slot (cable lock sold separately) |
| Cables Included | 2 x DVI-VGA cable - VGA to DVI-I , 2 x DVI cable - DVI-D to DVI-I |
| Backlight Life | 45,000 hours |
| Certified for Windows Vista | Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security. |
Power | |
| Power Supply | Internal |
| Input Voltage | AC 120/230 V (50/60 Hz) |
| Power Consumption (Typical) | 55 Watt |
| Power Consumption Stand by / Sleep | 2 Watt |
Environmental Standards | |
| EPEAT Compliant | EPEAT Silver |
| ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
| Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Environmental Parameters | |
| Min Operating Temperature | 10 °C |
| Max Operating Temperature | 35 °C |
| Humidity Range Operating | 20 - 80% |
The following resources are available for the HP LP2065 20.1" 1600 x 1200 8ms DVI-I LCD Monitor
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
