HP LP2475w 24" Widescreen 1920 x 1200 6ms HDMI 2 x DVI-I...
HP LP2475w 24" Widescreen 1920 x 1200 6ms HDMI 2 x DVI-I LCD Monitor
Key features
  • Adjustable comfort: get comfortable with adjustable height, tilt, swivel and 90-degree pivot rotation. The built-in HP Quick Release enables wall and arm mounting and tiling of multiple units for panoramic displays (mounting hardware sold separately)
  • Enhanced connectivity: get connected with DVI-I, component, S-video, composite, and DisplayPort inputs, as well as HDMI support for high-definition video. Enjoy quick peripheral connectivity from the monitor with the integrated six-port USB hub.
  • Impressive performance: enjoy crisp, clear, high-resolution onscreen presentation from the 1000:1 contrast ratio, sharp resolutions to 1920 x 1200, an extra-bright screen, and 92% color gamut on a 61 cm (24") diagonal wide-aspect screen.
  • Smart software: help protect against image retention and reduce energy costs with HP Display LiteSaver, which allows prescheduled Sleep mode. Adjust monitor settings and enable theft deterrence through the connected PC with HP Display Assistant.
Product codes
Documents
The super-sized HP LP2475w 24-inch Widescreen LCD Monitor offers premier performance and connectivity features in an elegant 24-inch diagonal wide-aspect screen engineered for power users, designers and workstation users who appreciate expansive widescreen presentation of their graphics, video, and data projects.
Product Description HP LP2475w - LCD monitor with TV tuner - 24"
Device Type LCD monitor - 24"
Features USB Hub
Panel Type S-IPS
Aspect Ratio 16:10
Native Resolution 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 400 cd/m²
Contrast Ratio 1000:1
Response Time 12 ms (On/Off); 6 ms (grey-to-grey)
Input Connectors HDMI, 2xDVI-I, DisplayPort, S-Video, composite video, component video
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, anti-static
Dimensions (WxDxH) 55.6 cm x 25.3 cm x 42.2 cm
Weight 9.1 kg
Localisation English / United Kingdom
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TCO '03, CSA, TUV, VCCI, GS, ISO 13406-2, MIC, FCC, RoHS, WEEE, ACA, CISPR
Resources
The following resources are available for the HP LP2475w 24" Widescreen 1920 x 1200 6ms HDMI 2 x DVI-I LCD Monitor
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP LP2475w 24" Widescr...
