Winning in business means working smarter. The HP Color LaserJet Pro M454 printer is designed to let you focus your time where it's most effective-helping to grow your business and staying ahead of the competition.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Product Description | HP Color LaserJet Pro M454dn - printer - colour - laser | Printer Type | Workgroup printer - laser - colour | Weight | 18.9 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 27 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 27 ppm - color (ISO) - A4 (210 x 297 mm) , Up to 28 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 28 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 49 ppm - black landscape - A5 (148 x 210 mm) , Up to 49 ppm - colour landscape - A5 (148 x 210 mm) , Up to 7 ppm - black portrait - A5 (148 x 210 mm) , Up to 7 ppm - colour portrait - A5 (148 x 210 mm) , Up to 24 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ipm - colour duplex - A4 (210 x 297 mm) , Up to 25 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 25 ipm - colour duplex - ANSI A (Letter) (216 x 279 mm) | Max Resolution (B&W) | 38400 x 600 dpi | Max Resolution (Colour) | 38400 x 600 dpi | Image Enhancement Technology | HP ImageREt 3600 | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, USB host | AirPrint Enabled | Yes | Processor | 1.2 GHz | RAM Installed (Max) | 512 MB (512 MB) | Flash Memory Installed (Max) | 256 MB (256 MB) | Language Simulation | PCL 5C, PostScript 3, PCL 6, PDF, URF, PWG | Media Type | Envelopes, labels, plain paper, photo paper, bond paper, recycled paper, punched paper, preprinted paper, postcards, glossy paper | Total Media Capacity | 300 sheets | Media Handling | 250-sheet input tray, 50-sheet multipurpose tray | Monthly Duty Cycle (max) | 50000 pages | Recommended Monthly Volume | 750 - 4000 pages | Networking | Print server | Printer Features | PANTONE calibrated, Instant-on Technology | System Requirements | Android, Microsoft Windows Server 2008 R2 x64 Edition, Apple iOS, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Microsoft Windows 7 / 8 / 10, Apple macOS 10.12, Apple macOS 10.13, Apple macOS 10.14 | Environmental Standards | EPEAT Silver | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 41.2 cm x 46.9 cm x 29.5 cm |
General | |
Printer | |
Built-in Devices | Status LCD |
Connectivity Technology | Wired |
PostScript Support | Standard |
First Print Out Time B/W | 9.7 sec |
First Print Out Time Colour | 11.3 sec |
Fonts Included | 84 x TrueType |
Processor | |
RAM | |
RAM Installed (Max) | 512 MB / 512 MB (max) |
Flash Memory | |
Flash Memory | 256 MB (installed) / 256 MB (max) |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm |
Envelope Sizes | International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm) |
Media Weight | 60 g/m² - 200 g/m² |
Media Weight (lbs) | 16 lbs - 52 lbs |
Media Feeders | Input tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 52 lbs (max)) , Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 52 lbs (max)) |
Max Media Capacity | 850 sheets |
Output Trays Capacity | 150 sheets |
Duty Cycle | |
Networking | |
Remote Management Protocol | SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP, IPv4 |
Security Protocols & Features | SSL, Apple Bonjour, TLS, 802.1x, EAP-TLS, PEAP, IPv6 support |
Expansion / Connectivity | |
Connections | 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC Class B certified, FCC Class A certified, Laser Class 1, FCC CFR47 Part 15, CECP, EN 62479:2010, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, ICES-003 issue 6, CISPR 32:2012, EN 55032:2015 Class B, EN 60825-1:2014, EN 55032:2012 Class B, IEC 60825-1:2014, CISPR 32:2015, RAL-UZ 205, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Power | |
Power Device | Power supply - internal |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 550 Watt |
Power Consumption Stand by | 17 Watt |
Power Consumption Sleep | 0.9 Watt |
Software / System Requirements | |
OS Required | Android, Microsoft Windows Server 2008 R2 x64 Edition, Apple iOS, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Microsoft Windows 7 / 8 / 10, Apple macOS 10.12, Apple macOS 10.13, Apple macOS 10.14 |
System Requirements Details | HD 2 GB |
Environmental Standards | |
EPEAT Compliant | EPEAT Silver |
Blue Angel | Yes |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Sound Emission (Idle) | 14 dBA |
Sound Emission (Operating) | 48 dBA |
Dimensions & Weight | |
Width | 41.2 cm |
Depth | 46.9 cm |
Height | 29.5 cm |
Weight | 18.9 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 49.7 cm |
Depth (Shipping) | 37.9 cm |
Height (Shipping) | 58.3 cm |
Weight (Shipping) | 22 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
