HP Mini-in-One 24" 1920x1080 5ms DisplayPort USB-C IPS L...
HP Mini-in-One 24" 1920x1080 5ms DisplayPort USB-C IPS LED Monitor
£384.86
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Effortlessly support your evolving business with our first display that powers a USFF PC with up to 65 watts. Connect to any HP Pro or Elite Desktop Mini and add your devices with 6 USB ports.
  • Reduce the threat of tampering with the built-in, fully-enclosed compartment and panels that secure your Mini. Block your webcam feed when not in use with the HP Privacy Camera shutter.
  • Take your clean desk to another level with an elegant design and simple slide-in mechanism that connects your Mini behind the screen through a USB-C™ cable and houses both discreetly out of view.
  • Diagonal Size: 23.8in
  • Max Resolution: 1920 x 1080
  • Response Time: 14ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, USB-C
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £388.35
Save £1.50
Maximize your workspace with the Mini-in-One display that fully encloses a USFF PC and is purpose-built to seamlessly connect, contain, secure, and power your Mini - from this generation to the next. Multi-task like a pro in Full HD resolution, and add your USB devices at the display.
Product Description HP Mini-in-One 24 - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Features USB 3.1 Gen 1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 800000:1 (dynamic)
Response Time 14 ms (grey-to-grey); 5 ms (overdrive)
Input Connectors DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black, silver (stand)
Dimensions (WxDxH) - with stand 53.96 cm x 24.2 cm x 50.38 cm
Weight 7.2 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Mini-in-One 24" 192...
£384.86
