HP Mono LaserJet Pro MFP M426fdn
Key features
  • Easily manage print jobs directly at the MFP – just tap and swipe the 7.6 cm touchscreen.
  • Easily print from a variety of smartphones and tablets – generally no setup or apps required.
  • Get the most prints for your money – with Original HP High Yield Black Toner cartridges with JetIntelligence.
  • Scan digital files directly to email, USB, network folders, and the cloud with preloaded business apps.
Product codes
Fast print, scan, copy, and fax performance, plus robust, comprehensive security built for how you work. This MFP finishes key tasks faster and guards against threats. Original HP Toner cartridges with JetIntelligence give you more pages.
Product Description HP LaserJet Pro MFP M426fdn - multifunction printer - B/W
Device Type Multifunction printer
Fax Type Plain paper
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (monochrome)
Monthly Duty Cycle (max) 80000 pages
Recommended Monthly Volume 750 - 4000 pages
Max Copying Speed Up to 38 ppm
Max Copying Resolution Up to 4800 x 600 dpi
Max Printing Speed Up to 38 ppm
Max Printing Resolution Up to 4800 x 600 dpi
Max Fax Transmission Speed 33.6 Kbps
Scanning 1200 x 1200 dpi
Display 3"
Original Size Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, light-weight paper, punched paper, preprinted paper
Standard Media Capacity 350 sheets
Bypass Feeder Capacity 100 sheets
Output Trays Capacity 150 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, Gigabit LAN, USB host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, save to USB flash drive, scan to e-mail, save to network folder, scan to Cloud, Instant-on Technology
Power AC 230 V (50/60Hz)
Dimensions (WxDxH) 42 cm x 39 cm x 32.3 cm
Weight 12.86 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified, Blue Angel
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Mono LaserJet Pro M...
