HP Officejet 200 Mobile Printer
£170.84
Delivery:
Key features
  • Power through the workday. Charge from home, in your car or office, and more.
  • Reduce charging interruptions with a long-lasting battery.
  • Simply print from your laptop or mobile devices wirelessly, with or without a router.
  • Type: Printer
  • Functionality: Printer
  • Wireless Capability: Wired, Wireless
  • Technology: Ink-jet
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Product codes
Make the world your office with powerful portable printing – no network necessary. This quick, quiet printer delivers more pages per cartridge and has a long-lasting battery life.
Product Description HP Officejet 200 Mobile Printer - printer - colour - ink-jet
Printer Type Personal printer - ink-jet - colour
Form Factor Portable
Weight 2.1 kg
Localisation Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Inkjet Technology HP Thermal Inkjet
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, pigment black
Media Size Class A4/Legal
Max Media Size Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom) 76.2 mm x 102 mm
Max Media Size (Custom) 216 mm x 356 mm
Print Speed Up to 20 ppm - black draft - A4 (210 x 297 mm) , Up to 18 ppm - colour draft - A4 (210 x 297 mm) , Up to 9 ppm - black laser quality , Up to 6 ppm - colour laser quality
Max Resolution (B&W) 1200 x 1200 dpi
Max Resolution (Colour) 4800 x 1200 dpi
Interface USB 2.0, USB host, Wi-Fi
AirPrint Enabled Yes
Preview Screen Size 2"
RAM Installed (Max) 128 MB (128 MB)
Language Simulation PCL 3
Media Type Envelopes, transparencies, greeting cards, labels, plain paper, photo paper, index cards
Total Media Capacity 50 sheets
Monthly Duty Cycle (max) 500 pages
Recommended Monthly Volume 100 - 300 pages
Networking Wireless network extender
Power AC 120/230 V
System Requirements Linux, Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits)
Dimensions (WxDxH) 36.4 cm x 18.6 cm x 6.9 cm
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
This item has been repaired under manufacturer warranty
Ref: C5ZV 042915
£141.76
product
Ref: C5ZV 042915
Accessories
Packaging
Functional
Software
Manuals
£141.76
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Officejet 200 Mobil...
£170.84
