HP Officejet 6950 All-in-One - Multifunction printer
SEAMLESS PERFORMANCE WITHOUT SLOWING DOWN
£101.62
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easily print from a variety of smartphones and tablets.
  • Print up to 2.5x as many pages with optional Original HP high-yield ink cartridges.
  • Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.
  • Set the pace for success with fast print, scan, and copy speeds.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Output Type: Colour
  • Wireless Capability: Wireless
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Product codes
Produce affordable, professional-quality colour that helps you stand out. Keep work moving with mobile printing and seamless mobile setup. Impressive speeds help you handle projects without slowing down. Save up to 70% on ink with HP Instant Ink.
Produce affordable, professional-quality colour that helps you stand out and save up to 70% on ink with HP Instant Ink.
Great value for professional home office colour
Get affordable, professional-quality colour and rich black text output – ideal for a variety of home office projects. Optional high-yield cartridges offer a better value for frequent printing. Rely on Original HP inks for documents that last.
Easy mobile printing, seamless mobile setup
Easily print when and where you need to from your smartphone, tablet, or notebook PC. Get up and running right out of the box, and connect the way you want to with wireless networking.
Seamless performance without slowing down
Take projects from start to finish with fast, easy all-in-one performance. Save paper with automatic two-sided printing, and speed through jobs with a 35-page automatic document feeder. Handle tasks directly at the 5.6 cm (2.2-inch) touchscreen.
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%.
Automatic document feeder
Allows multiple pages to be copied or scanned at one time
HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint.
Scan to email
Save time by sending scanned documents or photos directly from your printer to email recipients.
Easy mobile printing from HP
Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
HP Instant Ink
Save up to 70% on ink. Original HP ink delivered to your door with HP Instant Ink.
Product Description HP Officejet 6950 All-in-One - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation English / United Kingdom
Printing Technology Ink-jet (colour)
Inkjet Technology HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max) 15000 pages
Recommended Monthly Volume 200 - 800 pages
Max Copying Speed Up to 28 ppm (mono) / up to 22 ppm (colour)
Max Copying Resolution Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed Up to 29 ppm (mono) / up to 24 ppm (colour)
Max Printing Resolution Up to 600 x 1200 dpi (mono) / up to 1200 x 4800 dpi (colour)
Fax Resolutions 203 x 98 dpi, 200 x 200 dpi
Scanning 1200 x 1200 dpi
Display 2.2"
Original Size Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 35 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, cards, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity 225 sheets
Max Media Capacity 225 sheets
Output Trays Capacity 60 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB 2.0, Wi-Fi(n)
AirPrint Enabled Yes
Office Machine Features Save to USB flash drive, HP Auto Wireless Connect
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 46.37 cm x 51.8 cm x 22.867 cm
Weight 7.7 kg
Environmental Standards ENERGY STAR Qualified
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Officejet 6950 All-...
£101.62
