Easily print on a variety of paper sizes up to 29.7 x 42 cm (A3). Produce professional-quality colour for up to 50% less cost per-page than lasers on a printer that's ready for business.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Product Description | HP Officejet Pro 7720 Wide Format All-in-One - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | EMEA (excluding Israel, Saudi Arabia, South Africa) | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 30000 pages | Recommended Monthly Volume | 250 - 1500 pages | Max Copying Speed | Up to 18 ppm (mono) / up to 13 ppm (colour) | Max Copying Resolution | Up to 600 dpi (mono) / up to 600 dpi (colour) | Max Printing Speed | Up to 22 ppm (mono) / up to 18 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi | Scanning | 1200 dpi | Display | 2.65" | Original Size | 216 x 356 mm (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | 297 x 431 mm (max) | Media Type | Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper | Standard Media Capacity | 250 sheets | Output Trays Capacity | 75 sheets | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Scan to PC | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 58.49 cm x 69.06 cm x 30.64 cm | Weight | 15.5 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 2.65" |
Display Features | Touch screen |
Memory | |
Standard Memory | 512 MB |
Max Supported Memory | 512 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Copying Features | ID Card Copy, quality adjustment |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Nozzle Configuration | 1568 nozzles (black), 6272 nozzles (colour) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3 GUI |
Automatic Duplexing | Yes |
First Print Out Time B/W | 9 sec |
First Print Out Time Colour | 10 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 100 pages |
PC Faxing | Yes |
Fax Machine Features | |
Speed Dialing | 99 station(s) |
Broadcast Transmission | Yes |
Delayed Transmission | Yes |
Features | Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD) |
Document & Media Handling | |
Max Original Size | 216 x 356 mm |
Max Media Size | A3 |
Min Media Weight | 34 g/m² |
Max Media Weight | 250 g/m² |
Supported Media Type | Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm) |
Document & Media Handling Details | ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets |
Speed Details | Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 34 ppm (A4) - colour draft , Copying: up to 34 ppm (Letter A) - B/W draft , Copying: up to 34 ppm (Letter A) - colour draft , Printing: up to 34 ppm (Letter A) - B/W draft , Printing: up to 34 ppm (Letter A) - colour draft |
Connections | |
Interfaces | 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x modem - RJ-11 , 1 x USB host - 4 pin USB Type A |
Security Protocols & Features | Apple Bonjour, WEP, WPA, AES |
Operating System Support | Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition |
Software Included | HP Photo Creations, HP Update, Google Toolbar, Software HP Printer |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Miscellaneous | |
Compliant Standards | IPv6 Ready |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 58.49 cm |
Depth | 69.06 cm |
Height | 30.64 cm |
Weight | 15.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 67.7 cm |
Shipping Depth | 49.5 cm |
Shipping Height | 40.8 cm |
Shipping Weight | 19.5 kg |
Environmental Parameters | |
Sound Emission | 60 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
