HP OfficeJet Pro 7720 Wide Format All-in-One
FREE DELIVERY
Sorry but this product has been discontinued.
View used stock
Key features
  • Easily print from a variety of smartphones and tablets.
  • Print up to 29.7 x 42 cm (A3). Scan and copy up to legal size.
  • Print up to 3x as many black-text and 2x as many colour pages, with optional HP high-yield ink cartridges.
Product codes
Easily print on a variety of paper sizes up to 29.7 x 42 cm (A3). Produce professional-quality colour for up to 50% less cost per-page than lasers on a printer that's ready for business.
Product Description HP Officejet Pro 7720 Wide Format All-in-One - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology Ink-jet (colour)
Inkjet Technology HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max) 30000 pages
Recommended Monthly Volume 250 - 1500 pages
Max Copying Speed Up to 34 ppm (mono) / up to 34 ppm (colour)
Max Copying Resolution Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed Up to 34 ppm (mono) / up to 34 ppm (colour)
Max Printing Resolution Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning 1200 dpi
Display 2.65"
Original Size 216 x 356 mm (max)
Original Type Sheets
Document Feeder Capacity 35 sheets
Media Size 297 x 431 mm (max)
Media Type Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity 250 sheets
Output Trays Capacity 75 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Scan to PC
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 58.49 cm x 69.06 cm x 30.64 cm
Weight 15.5 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Damaged stock - Item is new but has packaging damage
Ref: D3ZB 039964
£57.24
product
Ref: D3ZB 039964
Accessories
Packaging
Functional
Software
Manuals
£57.24
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP OfficeJet Pro 7720...
