General |
Device Type |
Multifunction printer |
Fax Type |
Plain paper |
Printing Technology |
Ink-jet - colour |
Recommended Monthly Volume |
250 - 1500 pages |
Display Diagonal Size |
2.65" |
Colour Support |
Colour |
Display Features |
Touch screen |
Connection Availability |
Yes |
Interface |
USB 2.0, LAN, Wi-Fi(n), USB host |
AirPrint Enabled |
Yes |
Office Machine Features |
Scan to PC |
Localisation |
EMEA (excluding Israel, Saudi Arabia, South Africa) |
Memory |
Standard Memory |
512 MB |
Max Supported Memory |
512 MB |
Copying |
Max Copying Speed |
Up to 34 ppm (mono) / up to 34 ppm (colour) |
Max Copying Resolution |
Up to 600 dpi (mono) / up to 600 dpi (colour) |
Max Document Enlargement |
400% |
Max Document Reduction |
25% |
Maximum Copies |
99 |
Copying Features |
ID Card Copy, quality adjustment |
Printing |
Inkjet Technology |
HP Thermal Inkjet |
Nozzle Configuration |
1568 nozzles (black), 6272 nozzles (colour) |
Max Printing Resolution |
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) |
Max Printing Speed |
Ink Cartridge Configuration |
4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) |
Cyan, magenta, yellow, black |
Colour |
4-ink |
Printer Drivers / Emulations |
PCL 3 GUI |
Automatic Duplexing |
Yes |
First Print Out Time B/W |
9 sec |
Scanning |
Scan Element |
CIS |
Optical Resolution |
1200 dpi |
Grayscale Depth |
8-bit |
Colour Depth |
24-bit |
Fax Machine |
Max Transmission Speed |
33.6 Kbps |
Fax Resolutions |
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi |
Total Memory Capacity |
Up to 100 pages |
PC Faxing |
Yes |
Fax Machine Features |
Speed Dialing |
99 station(s) |
Broadcast Transmission |
Yes |
Delayed Transmission |
Yes |
Features |
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD) |
Document & Media Handling |
Max Original Size |
216 x 356 mm |
Original Type |
Sheets |
Document Feeder Capacity |
35 sheets |
Max Media Size |
A3 |
Min Media Weight |
60 g/m² |
Max Media Weight |
105 g/m² |
Supported Media Type |
Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper |
Supported Media Sizes |
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm) |
Standard Media Capacity |
250 sheets |
Output Trays Capacity |
75 sheets |
Document & Media Handling Details |
ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets |
Speed Details |
Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 18 ppm - B/W (ISO) , Printing: up to 22 ppm (A4) - B/W normal , Printing: up to 34 ppm (A4) - colour draft , Copying: up to 13 ppm (A4) - colour (ISO) , Copying: up to 18 ppm (A4) - B/W (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 34 ppm (A4) - colour draft |
Connections |
Interfaces |
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x modem - RJ-11 |
Security Protocols & Features |
Apple Bonjour, WEP, WPA, AES |
Operating System Support |
Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition |
Software Included |
HP Photo Creations, HP Update, Google Toolbar, Software HP Printer |
Power |
Voltage Required |
AC 120/230 V (50/60Hz) |
Power Consumption Operational |
29.4 Watt |
Power Consumption Standby |
6.02 Watt |
Power Consumption Sleep |
1.42 Watt |
Miscellaneous |
Compliant Standards |
BSMI, GS, CCC, FCC CFR47 Part 68, UL 60950-1 Second Edition, FCC CFR47 Part 15 B, IPv6 Ready, EAC, GB4943.1-2011, IEC 60950-1:2005 Second Edition, EN 61000-3-3:2013, EN 55024:2010, EN 61000-3-2:2014, R&TTE Directive 1999/5/EC, EN 55032:2012, TIA-968-B, ICES-003 issue 6, ICES-003 issue 6 Class B, CISPR 32:2012 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013 |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year |
Dimensions & Weight |
Width |
58.49 cm |
Depth |
44.48 cm |
Height |
38.58 cm |
Weight |
18.5 kg |
Dimensions & Weight (Shipping) |
Shipping Width |
67.7 cm |
Shipping Depth |
49.5 cm |
Shipping Height |
48.7 cm |
Shipping Weight |
23.13 kg |
Environmental Parameters |
Sound Emission |
61 dBA (operating) |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
8 - 85% |
