Print, scan, and copy in standout colour on sizes up to A3, for bold documents and presentations at up to 50% less cost per page than colour laser. Fax up to 21.6 x 35.6 cm (8.5 x 14 inches).
Dynamic security: Cartridges with non-HP chips might not work today or in the future.
Print, scan, copy and fax with ease
The OfficeJet Pro 7740 has the capability to print, scan, copy and fax documents in a wide range of sizes, making it an ideal addition to the office. With two paper trays, each capable of holding up to 250 sheets of paper, the printer also has a 35 page automatic document feeder (ADF) to save you time.
A 2.6" colour touchscreen control panel keeps you in control at all times, allowing you to select your preferred settings for each task.
Professional quality for less
Providing up to 50% lower cost per page than traditional laser printers, the OfficeJet Pro 7740 is an efficient choice for the office. It can produce water- and smear-resistant documents, as well as borderless brochure printing.
With automatic two-sided printing saving you paper, the printer can run on individual HP high-yield ink cartridges to ensure that you don't throw away useable ink.
Easy wireless printing and connectivity
The OfficeJet Pro 7740 features both built-in Ethernet and wireless connectivity, making it simple to access, print and share resources on a network. Using HP ePrint and other services such as Apple AirPrint, you can print documents remotely with ease.
You can manage your printing tasks and scans on the go using the free HP All-in-One Printer Remote mobile app, available on smart devices such as smartphones and tablets.
HP OfficeJet Pro 7740 All-in-One Wireless A3 Inkjet Printer with Fax, WiFi / Apple AirPrint / Google Cloud Print, Colour print / copy / scan / fax, Automatic double-sided printing, 4800 x 1200 dpi
Product Description | HP Officejet Pro 7740 All-in-One - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | EMEA (excluding Israel, Saudi Arabia, South Africa) | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 30000 pages | Recommended Monthly Volume | 250 - 1500 pages | Max Copying Speed | Up to 33 ppm (mono) / up to 31 ppm (colour) | Max Copying Resolution | Up to 600 dpi (mono) / up to 600 dpi (colour) | Max Printing Speed | Up to 34 ppm (mono) / up to 34 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi | Scanning | 1200 dpi | Display | 2.65" | Original Size | A3/Ledger (297 x 432 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | 297 x 431 mm (max) | Media Type | Plain paper, photo paper, thick paper, glossy paper, matte paper | Standard Media Capacity | 250 sheets | Output Trays Capacity | 75 sheets | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Save to USB flash drive, scan to e-mail, scan to folder, automatic paper sensor | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 58.4 cm x 46.69 cm x 38.33 cm | Weight | 19.5 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 2.65" |
Display Features | Touch screen |
Memory | |
Standard Memory | 512 MB |
Max Supported Memory | 512 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 6, PCL 3, PCL XL, PCL 3 GUI |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 100 pages |
Fax Machine Features | |
Speed Dialing | 100 station(s) |
Features | Colour faxing |
Document & Media Handling | |
Max Original Size | A3/Ledger (297 x 432 mm) |
Max Media Size | A3 |
Min Media Weight | 60 g/m² |
Max Media Weight | 105 g/m² |
Supported Media Type | Plain paper, photo paper, thick paper, glossy paper, matte paper |
Supported Media Sizes | A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 130 x 180 mm, 90 x 130 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm) |
Supported Envelope Sizes | US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm) |
Document & Media Handling Details | ADF - 35 sheets size: 76 x 127 mm - 215.9 x 355.6 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets |
Speed Details | Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 22 ppm (A4) - B/W normal , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Printing: up to 18 ppm (Letter A) - colour normal , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 31 ppm (A4) - colour draft |
Connections | |
Interfaces | 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 2 x modem - RJ-11 |
Operating System Support | Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 37 Watt |
Power Consumption Standby | 6.5 Watt |
Power Consumption Sleep | 1.47 Watt |
Miscellaneous | |
Included Accessories | Phone cable |
Consumables Included | 1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow) |
Compliant Standards | EN 61000-3-2:2006, EN 61000-3-3:2008, EN55022:2010 Class B, EN 55024:2010, CISPR 22:2008 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 58.4 cm |
Depth | 46.69 cm |
Height | 38.33 cm |
Weight | 19.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 24.45 kg |
Environmental Parameters | |
Sound Emission | 65 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
