HP OfficeJet Pro 7740 AIO Printer
£146.41
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Automatic two-sided printing, fast print speeds, and an auto document feeder help ease your day.
  • Create vibrant colour graphics and deep black text on a variety of papers from A4 to tabloid (A3).
  • Easily print documents and more from your smartphones and tablets, whether Apple®, Android™, or Windows.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Output Type: Colour
  • Wireless Capability: Wireless
  • Max Paper Size: 297 x 431 mm
Product codes
Print, scan, and copy in standout colour on sizes up to A3, for bold documents and presentations at up to 50% less cost per page than colour laser. Fax up to 21.6 x 35.6 cm (8.5 x 14 inches).
Dynamic security: Cartridges with non-HP chips might not work today or in the future.
Print, scan, copy and fax with ease
The OfficeJet Pro 7740 has the capability to print, scan, copy and fax documents in a wide range of sizes, making it an ideal addition to the office. With two paper trays, each capable of holding up to 250 sheets of paper, the printer also has a 35 page automatic document feeder (ADF) to save you time.
A 2.6" colour touchscreen control panel keeps you in control at all times, allowing you to select your preferred settings for each task.
Professional quality for less
Providing up to 50% lower cost per page than traditional laser printers, the OfficeJet Pro 7740 is an efficient choice for the office. It can produce water- and smear-resistant documents, as well as borderless brochure printing.
With automatic two-sided printing saving you paper, the printer can run on individual HP high-yield ink cartridges to ensure that you don't throw away useable ink.
Easy wireless printing and connectivity
The OfficeJet Pro 7740 features both built-in Ethernet and wireless connectivity, making it simple to access, print and share resources on a network. Using HP ePrint and other services such as Apple AirPrint, you can print documents remotely with ease.
You can manage your printing tasks and scans on the go using the free HP All-in-One Printer Remote mobile app, available on smart devices such as smartphones and tablets.
HP OfficeJet Pro 7740 All-in-One Wireless A3 Inkjet Printer with Fax, WiFi / Apple AirPrint / Google Cloud Print, Colour print / copy / scan / fax, Automatic double-sided printing, 4800 x 1200 dpi
Product Description HP Officejet Pro 7740 All-in-One - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology Ink-jet (colour)
Inkjet Technology HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max) 30000 pages
Recommended Monthly Volume 250 - 1500 pages
Max Copying Speed Up to 33 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed Up to 34 ppm (mono) / up to 34 ppm (colour)
Max Printing Resolution Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning 1200 dpi
Display 2.65"
Original Size A3/Ledger (297 x 432 mm) (max)
Original Type Sheets
Document Feeder Capacity 35 sheets
Media Size 297 x 431 mm (max)
Media Type Plain paper, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity 250 sheets
Output Trays Capacity 75 sheets
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Save to USB flash drive, scan to e-mail, scan to folder, automatic paper sensor
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 58.4 cm x 46.69 cm x 38.33 cm
Weight 19.5 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP OfficeJet Pro 7740...
£146.41
