HP Officejet Pro 8210 A4 printer 2400x1200dpi
£93.42
Delivery:
Key features
  • Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts.
  • Print directly from your mobile device without accessing the company network, from anywhere in the office.
  • Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.
  • Speed through print jobs, using fast two-sided printing.
  • Type: Printer
  • Functionality: Printer
  • Wireless Capability: Wired, Wireless
  • Technology: Thermal Ink-jet
  • Max Paper Size: A4 (210 x 297 mm)
Product codes
Control costs and printing practices, with affordable colour and comprehensive fleet-wide management. Print professional-quality colour and get seamless print management features. Boost efficiencies with a variety of mobile printing choices.
Features:
- Colour Printer- Perfect for Home use
- Print Only
- Paper Size - A4
- Connectivity - AirPrint, Network, USB
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
  • Print colour, black & white, and photos – your cost is the same.
  • Ink cartridges and delivery costs included in your monthly plan price.
  • No annual fee – change or cancel plans online anytime without penalty.
Stay on top of business. Complete high-volume jobs quickly and efficiently with fast two-sided printing. Easily print Microsoft® Office documents directly from your USB drive, and boost productivity with a 5.08-cm (2.0-inch) display.
  • Easily print Microsoft® Word and PowerPoint® files, plus Adobe® PDF files, directly from your USB drive.
  • Stay productive with a 5.08-cm (2.0-inch) display with keypad that’s intuitive and easy to use.
  • Support your high-volume office with a device designed to print 30,000 pages per month for up to five users.
Keep business moving. Easily print from your smartphone, tablet, or notebook PC, with a variety of mobile printing choices.
  • Easily print documents, photos, and more from a variety of smartphones and tablets.
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. With support for HP PCL 6, HP PCL 5c, and HP PS, you can expand print capabilities.
  • Easily take command of your printing environment from one central location, with HP Web Jetadmin.
  • Make it easy for all to print with one common driver.
  • Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
Product Description HP Officejet Pro 8210 - printer - colour - ink-jet
Printer Type Workgroup printer - ink-jet - colour
Weight 8.2 kg
Localisation EMEA (excluding Israel, Saudi Arabia)
Inkjet Technology HP Thermal Inkjet
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, black
Media Size Class A4
Max Media Size A4 (210 x 297 mm)
Print Speed Up to 22 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 18 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 12 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 10 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W) 1200 x 1200 dpi
Max Resolution (Colour) 2400 x 1200 dpi
Automatic Duplexing Yes
Interface USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled Yes
Preview Screen Size 2"
RAM Installed (Max) 256 MB (256 MB)
Language Simulation PCL 3, PCL 5C, PostScript 3, PCL 6, PCL XL, PDF
Media Type Envelopes, plain paper, photo paper, cards, postcards
Total Media Capacity 250 sheets
Media Handling 250-sheet input tray
Recommended Monthly Volume 250 - 1500 pages
Networking Print server
Power AC 120/230 V
System Requirements Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
Manufacturer Warranty 3-year warranty with product registration
Dimensions (WxDxH) 49.8 cm x 41.9 cm x 20.4 cm
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: C489 042886
£38.32
product
Ref: C489 042886
Accessories
Packaging
Functional
Software
Manuals
£38.32
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Ink
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Officejet Pro 8210...
£93.42
