HP OfficeJet Pro 8218 Printer
£130.36
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts.
  • Print directly from your mobile device without accessing the company network, from anywhere in the office.
  • Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.
  • Speed through print jobs, using fast two-sided printing.
  • Type: Printer
  • Functionality: Printer
  • Wireless Capability: Wired, Wireless
  • Max Paper Size: A4 (210 x 297 mm)
  • Stock Status: In Stock
Product codes
Control costs and printing practices, with affordable colour and comprehensive fleet-wide management. Print professional-quality colour and get seamless print management features. Boost efficiencies with a variety of mobile printing choices.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Save up to 70% on ink with HP Instant Ink
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Everything you need to finish jobs fast
Stay on top of business. Complete high-volume jobs quickly and efficiently with fast two-sided printing. Easily print Microsoft® Office documents directly from your USB drive, and boost productivity with a 5.08-cm (2.0-inch) display.
Mobile printing that keeps your business covered
Keep business moving. Easily print from your smartphone, tablet, or notebook PC, with a variety of mobile printing choices.
Superior fleet control, seamless management
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. With support for HP PCL 6, HP PCL 5c, and HP PS, you can expand print capabilities.
Product Description HP Officejet Pro 8218 - printer - colour - ink-jet
Printer Type Workgroup printer - ink-jet - colour
Weight 8.2 kg
Localisation EMEA (excluding Israel, Saudi Arabia)
Inkjet Technology HP Thermal Inkjet
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, black
Media Size Class A4
Max Media Size A4 (210 x 297 mm)
Print Speed Up to 20 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - color (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W) 1200 x 1200 dpi
Max Resolution (Colour) 2400 x 1200 dpi
Automatic Duplexing Yes
Interface USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled Yes
Preview Screen Size 2"
RAM Installed (Max) 256 MB (256 MB)
Language Simulation PCL 3, PCL 5C, PostScript 3, PCL 6, PCL XL, PDF
Media Type Envelopes, plain paper, photo paper, cards, postcards
Total Media Capacity 500 sheets
Media Handling 500-sheet input tray
Recommended Monthly Volume 250 - 1500 pages
Networking Print server
Power AC 120/230 V
System Requirements Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
Dimensions (WxDxH) 49.8 cm x 41.9 cm x 20.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP OfficeJet Pro 8218...
£130.36
