Key features:
Do everything with print, scan, copy and fax functions
Enjoy professional results at half the cost
Print wirelessly using Apple AirPrint and Google Cloud Print
The OfficeJet Pro 8728 All-in-One printer handles any task from printing and copying to faxing and scanning, making it ideal for handling any kind of creative or office project.
Print professional quality prints at 50% less cost per page of laser printers with fast double-sided printing and scanning performance. The OfficeJet Pro 8728 even uses less energy than lasers to save you time and money.
Print wirelessly with Apple AirPrint and Google Cloud Print
The OfficeJet Pro 8728 works with Apple AirPrint and Google Cloud Print Print, allowing you to print from anywhere using your smartphone or tablet without having to go near a desktop.
HP OfficeJet Pro 8728 All-in-One Wireless Inkjet Printer, Save up to 50% on ink compared to a colour laser printer, WiFi / Apple AirPrint / Google Cloud Print, Colour print / copy / scan / fax, Automatic double-sided printing, 4800 x 1200 dpi
