HP OfficeJet Pro 8730 AIO Colour InkJet MFP
£315.62
Delivery:
Standard: 1-3 working days
Key features
  • Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts.
  • Print with just a touch of your NFC-enabled mobile device to the printer – no company network needed.
  • Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.
  • Speed through print jobs, using superfast two-sided printing.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Output Type: Colour
  • Technology: Ink-jet
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Product codes
Maximise your print environment with space-saving HP Print Forward Design and professional-quality, low-cost colour. Help reduce costs with fleet management solutions. Stay productive with an all-in-one designed for high-volume enterprises.
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door. Print colour, black & white, and photos – your cost is the same. Ink cartridges and delivery costs included in your monthly plan price. No annual fee – change or cancel plans online anytime without penalty.
Experience revolutionary HP Print Forward Design. Get high speeds for two-sided print and scan jobs with laser-like paper handling, and preserve real estate with space-saving design. Print longer without reloading, with an optional second paper tray.
Speed through print jobs, using superfast two-sided printing. Breeze through multipage documents with one-pass two-sided scanning and a 50-page automatic document feeder. Revolutionary design delivers laser-like paper handling and superfast print speeds. Print more and reload less. Increase paper capacity to 500 sheets with a second 250-sheet paper tray.
Keep business moving from anywhere in the office. Connect to devices with touch-to-print functionality. Easily print when and where you need to from your smartphone, tablet, or notebook PC.
Print with just a touch of your NFC-enabled mobile device to the printer – no company network needed. Print directly from your mobile device without accessing the company network, from anywhere in the office. Easily print from a variety of smartphones and tablets. Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. Expand print capabilities with support for HP PCL 6, HP PCL 5c, and HP PS printing options.
Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts. Easily print Microsoft® Word and PowerPoint® files, plus Adobe® PDF files, directly from your USB drive. Experience a new style of business printing and imaging, with HP JetAdvantage On Demand solutions. Easily take command of your printing environment from one central location, with HP Web Jetadmin.
Product Description HP Officejet Pro 8730 All-in-One - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology Ink-jet (colour)
Inkjet Technology HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max) 30000 pages
Recommended Monthly Volume 200 - 2000 pages
Max Copying Speed Up to 37 ppm (mono) / up to 37 ppm (colour)
Max Copying Resolution Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed Up to 36 ppm (mono) / up to 36 ppm (colour)
Max Printing Resolution Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Fax Resolutions 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning 1200 x 1200 dpi
Display 4.3"
Original Size Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity 250 sheets
Max Media Capacity 500 sheets
Output Trays Capacity 150 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, scan to e-mail, fax to e-mail
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 50 cm x 53.1 cm x 32.8 cm
Weight 15.2 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 3-year warranty with product registration
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer. PLEASE NOTE. Ink is not included
Ref: C4P2 042230
£146.92
product
Ref: C4P2 042230
Accessories
Packaging
Functional
Software
Manuals
£146.92
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Ink
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP OfficeJet Pro 8730...
£315.62
