Count on fast print speeds up to to 22 ppm, automatic two-sided printing, reliable Wi-Fi connectivity, and a 250 sheet paper tray. Choose HP+ and get 6 months of Instant Ink and 1 extra year HP warranty with use of Original HP Ink.
This printer is best for shared home offices managing records and printing professional colour presentations.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits.
*Choose to activate HP+ at printer set up. Requires ongoing internet connection, set up of an HP account and use of only Original HP Ink or Toner for the life of the printer.
Learn more: hp.com
Product Description | HP Officejet Pro 9010e All-in-One - multifunction printer - colour - HP Instant Ink eligible | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | United Kingdom, Ireland | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 25000 pages | Recommended Monthly Volume | 1500 pages | Max Copying Speed | Up to 21 ppm (mono) / up to 15 ppm (colour) | Max Copying Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Printing Speed | Up to 22 ppm (mono) / up to 18 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi | Scanning | 1200 x 1200 dpi | Display | 2.7" | Original Size | 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper | Standard Media Capacity | 250 sheets | Max Media Capacity | 250 sheets | Output Trays Capacity | 60 sheets | Automatic Duplexing | Yes (copying) Yes (printing) Yes (scanning) | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 43.93 cm x 38.22 cm x 27.8 cm | Weight | 9.29 kg | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 2.7" |
Display Colour Support | Colour |
Display Features | Touch screen |
Memory | |
Standard Memory | 512 MB |
Max Supported Memory | 512 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Automatic Duplexing | Yes |
Copying Features | ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Nozzle Configuration | 6272 nozzles |
Ink Cartridge Configuration | 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black) |
Ink Palette Supported (Colours) | Pigment cyan, pigment magenta, pigment yellow, pigment black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3 GUI |
First Print Out Time B/W | 9 sec |
First Print Out Time Colour | 10 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 100 pages |
Fax Printing Speed | Up to 15 ppm |
Fax Printing Resolution | 203 x 196 dpi |
PC Faxing | Yes |
Fax Machine Features | |
Speed Dialing | 99 station(s) |
Delayed Transmission | Yes |
Features | Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending |
Document & Media Handling | |
Min Original Size | 76.2 x 127 mm |
Max Original Size | Legal (216 x 356 mm) |
Min Media Size | 76.2 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 280 g/m² |
Min Media Weight (lb) | 16 lbs |
Max Media Weight (lb) | 110 lbs |
Supported Media Type | Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm |
Supported Envelope Sizes | International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), A4 (210 x 297 mm) |
Borderless Photo Sizes | ANSI A (Letter) (216 x 279 mm) |
Document & Media Handling Details | ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets |
Speed Details | Printing: up to 22 ppm (A4) - B/W (ISO) , Printing: up to 18 ppm (A4) - colour (ISO) , Printing: up to 32 ppm (A4) - B/W draft , Printing: up to 32 ppm (A4) - colour draft , Copying: up to 32 ppm (A4) - B/W draft , Copying: up to 32 ppm (A4) - colour draft , Scanning: up to 8 ppm (A4) - B/W , Scanning: up to 8 ipm (A4) - colour , Scanning: up to 4 ppm (A4) - B/W duplex , Scanning: up to 4 ppm (A4) - colour duplex , Copying: up to 5 ppm (A4) - B/W best , Copying: up to 4 ppm (A4) - colour best |
Connections | |
Interfaces | 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A |
Security Protocols & Features | SSL, TLS, WPA2, 802.1x, WPA2-Enterprise |
Operating System Support | Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x |
Software Included | Software HP Printer |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 30 Watt |
Power Consumption Standby | 5.8 Watt |
Power Consumption Sleep | 1.2 Watt |
Miscellaneous | |
First Copy Out Time B/W | 7 sec |
First Copy Out Time Colour | 9 sec |
Consumables Included | 1 x ink cartridge (black) - HP 963 , 1 x ink cartridge (cyan) - HP 963 , 1 x ink cartridge (magenta) - HP 963 , 1 x ink cartridge (yellow) - HP 963 |
Compliant Standards | BSMI, GS, IC CS-03, CCC, ANATEL, FCC CFR47 Part 15 B, EAC, ICASA, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, TIA-1096, EN 301 489-1, EN 61000-3-2:2014, CNC, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, TIA-968-B, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, SCT, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts - 1 year , Technical support - web support - 1 year |
Dimensions & Weight | |
Width | 43.93 cm |
Depth | 38.22 cm |
Height | 27.8 cm |
Weight | 9.29 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 49.7 cm |
Shipping Depth | 32.5 cm |
Shipping Height | 40.9 cm |
Shipping Weight | 11.02 kg |
Environmental Parameters | |
Sound Emission | 63 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
